    Selection.add ??? possible?
    4 Posts 4 Posters 489 Views 4 Watching
    • artmusicstudioA Offline
      artmusicstudio
      hi,
      when i have
      model = Sketchup.active_model
      sel = model.selection
      and create a edge-copy from a given edge (from an edge-array : edges)
      entities2 = Sketchup.active_model.entities
      vertex = edges[0].start
      pt_start = vertex.position
      vertex = edges[0].end
      pt_end = vertex.position
      edge2 = entities2.add_line(pt_start, pt_end)
      how could i ADD the new edge2 to the sel ??? (merge ?)
      is it possible?
      after this the further code should realise sel incl. the new adge2 as USER's SELECTION .
      thanx
      stan
      • sdmitchS Offline
        sdmitch
        I don't think Sketchup will allow you to place one edge on top another in the same context. The copy would have to be created in a group then sel.add edge2 would add it to the selection.
        http://sdmitch.blogspot.com/
          sel.add(edge2)
          BUT best to test it's valid - edge2.valid?
          BUT beware!
          The entity must be in the model.active_entities context...
          You can 'cross-thread' selected entities BUT it will crash SketchUp...
          • tt_suT Offline
            tt_su
            Was that a question on how? Or did you experience issues with Selection.add (because that is exactly the API method to do what you requested: http://www.sketchup.com/intl/en/developer/docs/ourdoc/selection#add)
