    A small "entity to group" problem
    4 Posts 3 Posters 492 Views 3 Watching
    • artmusicstudioA Offline
      artmusicstudio
      hi,
      i wopuld be greatful for a small tip:
      i have a @main_element,
      which contains some faces
      when i iterate thru the entities, i can check the normal, see the top face and push pull
      i also can create a new group within the @main_element-container and put an edge in it.
      buit when i want to put one of the @ main_element's entities (here it is a face) into this new group,
      i get a "parent" problem, which i don't understand:
      @selection.each { |entity|
      		if entity.is_a?(Sketchup;;Face)
      			check_normal_for_horizontal(entity) #my own method
      			puts @bgf_count_normal # 1 is face top
      			if @bgf_count_normal == 1
      				puts "---FACE UP ... IN MAIN-ELEMENT"
      				entities = @main_element.entities
      				group = entities.add_group
      				entities2 = group.entities
      				point1 = Geom;;Point3d.new(0,0,0)
      				point2 = Geom;;Point3d.new(2000,200,200) #works
       				edges = entities2.add_edges point1, point2
      				loop = entity.outer_loop # does not work
      				edgearray = loop.edges
                                      floor = entities2.add_face(edgearray)
      why does the new face from edgearray not appear in the group?
      info from console:
      Error: #<ArgumentError: Edge has different parent>
      C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/02.rb:959:in `add_face'
      thanx
      stan
        Tip:
        Don't iterate a selection,
        Its referring changes as you remove items!
        Iterate a snapshot array of it
        @selection.to_a.
        Next...
        You can't reassign entities from one context to another.
        Although you CAN 'add entities' in the active_entities context into a group.entities in the same context.
        BUT you can't do it the way you want - because you are attempting to make a face in one context using the edges in another...
        Try something like:
        varray = entity.outer_loop.vertices floor = entities2.add_face(varray)
        You can use an array of vertices as well as points...
          artmusicstudio
          hi tig,
          that's fantastic,
          point 2 : solved ( i already though of retrieving the points , but vertices work perfectly!
          for point 1:
          got it working, super. thanx.
          by the way, is there a code for deliting an array of edges directly ? or do i have to iterate thru the array and erase one after another?
          in my case i create a copy of a face in the new group (>> vertices)
          and wantto delete the original entity incl. edges.
          thanx a lot
          stan
          • Dan RathbunD Offline
            Dan Rathbun
            @artmusicstudio said:
            ..., is there a code for deliting an array of edges directly ? or do i have to iterate thru the array and erase one after another?
            use Entities.erase_entities()
            The argument can be a single entity, or an array of entities.
            ALSO... Ruby has an "accordian operator" the * that can be used to expand an array into a argument list, or compress arguments in an array.
            IF erase_entities also takes a list of multiple entities, you could convert the aray to a list like:
            my_ents.erase_entities( *my_edge_array )
            I'm not here much anymore.
