    Unit inputs limitation in older plugin
    extensions
    3 Posts 2 Posters 622 Views 2 Watching
      slave
      I have downloaded older plugin from Ruby Depot,"Geodesic_Sketchup.rb",
      but input for radius are in inch only.
      Converting mm to inch, like decimal number is not accepted by plugin.
      Any possibility to add option for mm, or to use sketchup units?
      (if plugin can be modified ,depend of license)
      Thank you in advance for any help/advice.
      • AdamBA Offline
        AdamB
        Here you go. (NB the SCF forum has converted ":octahedron" into 😮ctahedron)
        Open the Geodesic_SketchUp.rb script in a text editor and replace the lines:
        def self.create( frequency = nil, primitive = :open_mouth:ctahedron, radius = 36 )
        	if !frequency
        		prompts = [ 'Primitive:', 'Radius (in "):', 'Subdivisions:' ]
        		values = [ primitive.to_s, radius, 2 ]
        		primitive_types = ['tetrahedron|octahedron|icosahedron']
        		results = inputbox prompts, values, primitive_types, 'Create Geodesic'
        		return unless results
        		primitive, radius, frequency = results
        		primitive = primitive.to_sym
        with this :
        def self.create( frequency = nil, primitive = :open_mouth:ctahedron, radius = "36" )
        	if !frequency
        		radius = Sketchup.parse_length(radius.to_s)
        Save it and restart Sketchup.
        Adam
          slave
          Thank you Adam,
          I appreciate your help and very fast replay.
          Work as it need.
          Thanks again
