    How to get real position of vertex
    2 Posts 2 Posters 451 Views 2 Watching
      curator
      Hi there,
      I have problems understanding the data structure of SketchUp. Lets assume I have a empty scene and draw a simple rectangle. Then I can use ruby console like this
      Sketchup.active_model.entities.at(4).vertices.at(1).position
      Point3d(0, 3.93701, 0)
      Ok. Then I resize the rectangle using the scale tool (holding CTRL) by some factor and get
      different values
      Point3d(0.984252, 2.95276, 0)
      Ok, undo the rescaling and put the rectangle to a group. Then the call is
      Sketchup.active_model.entities.at(0).entities.at(1).vertices.at(0).position
      Then I rescale as above, but this time the group. I again try
      The thing is, that the position of the vertex has changed in the scene, but the output as above does not change. How can I get the "real" position instead?
      kind regards,
      curator
        Get the "container[s]" of the entities, get their "transformation[s]", then transform the vertex's point to match.
        Then you'll have the point in the model coordinate system, not the point in the container's coordinates system...
        This will give you the path through the nesting:
        http://www.sketchup.com/intl/en/developer/docs/ourdoc/model#active_path
        See these methods to get the 'accumulated' transformations of each container:
        http://www.sketchup.com/intl/en/developer/docs/ourdoc/transformation
