    Followme in ruby not working as expected
    5 Posts 3 Posters 679 Views 3 Watching
    • J
      JohnRees
      My first post! I'm trying to write a sketchup importer that reads coordinates of walls from a text file then draws a line using the coordinates and draws the wall using followme.
      The reason I want to use followme rather than just drawing faces is I want to draw the external brick leave and then the internal block wall and have corners drawn neatly.
      Here is some example code (similar to how the importer will work)
      ` mod = Sketchup.active_model # Open model
      ent = mod.entities # All entities in model
      sel = mod.selection # Current selection
      wallGroup = ent.add_group
      #face points
      pt1 = [0,0,0]
      pt2 = [0,10,0]
      pt3 = [0,10,100]
      pt4 = [0,0,100]
      #line points
      lpt1 = [0,0,0]
      lpt2 = [150,0,0]
      lpt3 = [100,150,0]
      lpt4 = [0,100,0]
      face = ent.add_face pt1, pt2, pt3, pt4
      line = ent.add_line lpt1, lpt2
      line = ent.add_line lpt2, lpt3
      #the line below doesn't work with follow me
      #line = ent.add_line lpt3, lpt4
      #line = ent.add_line lpt4, lpt1
      status = face.followme line`
      follow me seems to be inconsistent in its behavior. If I draw the first two lines and use followme it works exactly how I want and the wall looks like this.
      https://dl.dropboxusercontent.com/u/3806610/2014-06-20_1620.png
      If however I try drawing three lines then followme I get this.
      https://dl.dropboxusercontent.com/u/3806610/2014-06-20_1620_001.png
      Can anyone explain where I'm going wrong? Any help is appreciated!
      • TIGT
        Draw the 3 edges in one go thus:
        face = ent.add_face(pt1, pt2, pt3, pt4) lines = ent.add_edges(lpt1, lpt2, lpt3, lpt4) status = face.followme(lines)
        Incidentally you set ent=model.entities - it would be better to refer to the active entities in case the user is in an edit mode...
        ent=model.active_entities
        You also make a group and do not use it ?
        Why not add the new geometry directly to that? Thus:
        ents=wallGroup.entities
        then refer to that ents rather than ent, thus:
        face = ents.add_face(pt1, pt2, pt3, pt4) lines = ents.add_edges(lpt1, lpt2, lpt3, lpt4) status = face.followme(lines)
        • J
          JohnRees
          Thanks TIG! Will give that a go.
          • J
            Jim
            Is this what you are after?
            #face points
            pt1 = [0,0,0]
            pt2 = [0,10,0]
            pt3 = [0,10,100]
            pt4 = [0,0,100]
            #line points
            lpt1 = [0,0,0]
            lpt2 = [150,0,0]
            lpt3 = [100,150,0]
            lpt4 = [0,100,0]
            path = []
            path.push ent.add_line lpt1, lpt2
            path.push ent.add_line lpt2, lpt3
            path.push ent.add_line lpt3, lpt4
            status = face.followme path
            • J
              JohnRees
              Hi Jim,
              Yes that's exactly what I wanted! Thank you. I've managed to get the code to draw the internal leaf as well. The only small problem now is I'm repeating myself in the code to get this result, which seems wrong.
              Is there anyway to get this result without have almost identical code running twice? Is there anyway to push two faces along the same path at the same time to give the result below?
              https://dl.dropboxusercontent.com/u/3806610/2014-06-23_1143.png
              fyi this is how the code looks now.
              #face points
              pt1 = [0,0,0]
              pt2 = [0,10,0]
              pt3 = [0,10,100]
              pt4 = [0,0,100]
              pt5 = [0,20,0]
              pt6 = [0,30,0]
              pt7 = [0,30,100]
              pt8 = [0,20,100]
              #line points
              lpt1 = [0,0,0]
              lpt2 = [150,0,0]
              lpt3 = [100,150,0]
              lpt4 = [0,100,0]
              path = []
              path = []
              face= ent.add_face pt5, pt6, pt7, pt8
              status = face.followme path`
