    Help with stl import export
    9 Posts 5 Posters 767 Views 5 Watching
    • M
      mcgaffin
      I have upgraded to 2014 from 2013. I am unable to get the stl import export plugins to work. I have auto installed but with no success. The plugin manager shows su2stl is loaded but it is not present in the menu. The stl import/export v2 from the plugin store does not show up as present.
      • M
        mac1
        HAVE YOU CHECKED UNDER THE FILE DROP DOWN VS PLUGIN?
        • M
          mcgaffin
          yes. I have uninstalled and reinstalled the program. Deleted v2013 and all associated folders.
          • J
            Jim
            Install SketchUp STL using the Extensions Warehouse instead of su2stl.rb from the Plugins Store. The Extensions Warehouse in under the Window menu in SketchUp.
            ERROR: The request could not be satisfied
            (extensions.sketchup.com)
            • M
              mcgaffin
              I did as you suggested. Nothing happens. I downladed it. It does not appear in the plugin manager or under extensions to install
              • olisheaO
                olishea
                Have you used this stl exporter instead? Works better for me, not tried installing in 2014 though.
                404 Not Found
                (brettbeauregard.com)
                oli
                  And this one ? by Didier Bur
                  • J
                    Jim
                    404 Not Found
                    Works better how?
                    • olisheaO
                      olishea
                      @jim said:
                      [Works better how?
                      The other one didn't work for me on mac v8, not sure why. The stl mm exporter just worked straight away and in the units I need.
                      oli
