    Method to Explode Groups by name beginning...
    3 Posts 2 Posters 310 Views 2 Watching
      Skastafari
      I need help with a method to explode select groups in my model, they are named "wall*".
      So they would appear in model as "wall_1_3, wall_1_4, etc. They must all be exploded, but nothing else in the model. They are not sub-grouped, so no re-curse needed. I was playing with something like...
      model=Sketchup.active_model
      entities=model.active_entities
      Sketchup.active_model.active_entities.each{|e|e.explode if e.name =~ /\A(wall-)/}
      This does not work. I am unsure of method and syntax, and being humbled my now apparent limited skills. Any help would be appreciated.
        Try
        Sketchup.active_model.active_entities.grep(Sketchup;;Group).each{|e| e.explode if e.name=~/^[Ww]all/ }
        Any group in the current active entities that has a name starting with [Ww]all should be exploded...
        Obviously enclosing it in a module/method and start/commit_operation is needed...
        But this the core code...
          Skastafari
          Looks like you focused only on group class, and corrected the wall name syntax, and I am very grateful as it now works! Thanks Tig 😎
