    How do you intersect two faces?
    5 Posts 3 Posters 892 Views 3 Watching
      CAUL
      I want to intersect two groups ( g0, g1) and put the intersection edges in a third group. Since intersect_with is very slow on complex geometry it should pay to find pairs of faces from g0 and g1 that might intersect and then intersect those pairs separately. An example, I have two groups with roughly 11000 faces each. This requires 121 million face/face comparisons, however, with some space hashing this number drops to ~400.000 from which ~4000 pairs of potential face intersections are extracted (ie. face pairs whose bounding boxes intersect). The whole procedure takes about a second. (To intersect the groups from the UI takes 16 minutes..)
      Now, is there a way in sketchup to intersect just two faces? I'm at loss on how to use intersect_with for this and the Geom class contains only plane/plane intersection.
      • jolranJ Offline
        jolran
        Join the party...
        intersect_with is slow, but probably necessary evil.
        That's quite a large collection you are having.
        I found it ever so slightly faster in 2Dboolean to intersect with 1 of the groups containing edges only, to cut out the desired frame of desired geometry. But in your case that might not aid.
        I reported a strange behavior from that that never got answered, or maybe it's so well known it did not deserve an answer..
        "Edge collection still remembers face" - error, sort of thing..(scroll to my post)
        http://sketchucation.com/forums/viewtopic.php?f=180%26amp;t=55238%26amp;hilit=+intersect
        There was some post long time ago about using linesweeps instead, in the Cartesian plane.
        And perhaps break edges on "hit". I don't think it's trivial to build something like that..
        Maybe if it could be ported to C doing the calculations, however the cost..
        TIG's many plugins use intersections quite often. You should dig in there..
        If you would come up with something revolutionary you'd be a hero..
          slbaumgartner
          The heart of your problem is that intersect_with is an instance method of the Entities collection class. So, you need to create a temporary Entities collection and copy one of the Faces into it. For instance (assuming that the Faces are drawn in model coordinates - otherwise you will need to use something other than the identity Transformation):
          temp_ents = Sketchup.active_model.entities.add_group.entities # can reuse this if purge between pairs of Faces
          temp_ents.add_face(face1.edges)
          ident = Geom;;Transformation.new
          intersect_arr = temp_ents.intersect_with(false, ident, temp_ents, ident, false, face2)
          Because it is all Ruby, I don't know whether this will actually be any faster than letting the built-in function handle the whole thing though.
          Steve
          • jolranJ Offline
            jolran
            This is what I do (sort of) in 2dboolean. But with 11000 faces πŸ˜• ...
            20 seconds is better than 25 πŸ˜„ every optimization counts or are worth trying
              CAUL
              Thanks for the replies!
              slbaumgartner, splendid advice. It worked much smoother than I thought it would. The code is attached below. Here are some results from intersecting the two columns in the example file:
              • Intersect from UI: 983s
              • Outer shell (*****): 161s
              • g0.intersect_with g1 (******): 104s
              • Intersect face pairs: 4s
              () Outer shell is probably dominated by the intersect
              *) In order to produce all edges for coplanar cuts two calls to intersect_with has to be made with the groups reversed. The result above is for a single call.
              cuttest.zip
              CAUL_CutTest0.3.rb
