    Frame rate - fps in loose geometry versus components
    2 Posts 2 Posters 311 Views 2 Watching
    • alexandre skA
      alexandre sk
      I am obsessed about frames per second, 🤓
      So i found a very strange situation, most you guys probably know it. But I did not.
      I made some tests with the Test.time_display
      The 4 images have the exact same geometry, same number of faces and same number of edges. The only difference is the components or groups.
      The first is only loose geometry - 7.9fps
      the second every box is a component (10201 components) - 1.4fps
      the third every line is a component with 100 boxes inside (101 components ) - 11.2fps
      the four every box is a component and every line also is a componente (10302 comp ) - 1.4fps
      so I think sketchup takes a lot of time to open one instance and see its properties ( scale position etc ) so it's better have fewer components with more geometry inside for optimum frames per second. Of course its only need for very big models.
      teste time display 03 - compoentes individuais nested em um compo cada linha.jpg
      • KrisidiousK
        Krisidious
        nice to know...
        By: Kristoff Rand
