    [Plugin] Eneroth Railroad System (v 0.1.21)
    364 Posts 43 Posters 108.9k Views 41 Watching
    • eneroth3E Offline
      eneroth3
      @rv1974 said:
      Without spaghetti western style bandits in library the plugin is rather pointless.
      How am I supposed to robber the train? πŸ˜„
      bang-bang
      Make a 2d face me component of a person pointing a gun and follow the train with the camera. Then you can be inside the train and have a person standing at the side of the track pointing the gun at you when driving by πŸ˜„
      My website: http://julia-christina-eneroth.se/
        rv1974
        SurstrΓΆmming western?
        I see..πŸ˜„
          Reading the "Read me" ! 😎
          That is a complete universe! 😲
            Added to PluginStore
            • eneroth3E Offline
              eneroth3
              πŸ‘
                Lz
                Very impressive. It's a shame that it doesn't seem to work on my SU 8 (i'm using WinXP btw). But i'm planning on upgrading anyway so i might take another look sometime in the future.
                either way, if you need help adding new rolling stock/locomotives for future versions, please let me know and i'll gladly try to help out with some models. German locomotives are one of my favorites too.
                • OxerO Offline
                  Oxer
                  I tried to install on Mac 10.9.3 &SU2014 but it appears Load Error
                  %(#BF0000)[Error al cargar archivo ene_railroad.rb
                  Error: #<TypeError: wrong argument type nil (expected Regexp)>
                  /Users/Oxer/Library/Application Support/SketchUp 2014/SketchUp/Plugins/ene_railroad.rb:202:in `gsub'
                  /Users/Oxer/Library/Application Support/SketchUp 2014/SketchUp/Plugins/ene_railroad.rb:202:in `module:Ene_Railroad'
                  /Users/Oxer/Library/Application Support/SketchUp 2014/SketchUp/Plugins/ene_railroad.rb:200:in `<top (required)>']
                  http://www.oxervision.blogspot.com/
                  • ElibjrE Offline
                    Elibjr
                    Wow! There is no word to describe how amazing this plugin is! There is a LOT of work here! Like someone said before,I would love to see this in conjunction with the "Enderoth Roadway System" with moving cars! πŸ˜„ This could then be the basis for a 'City Engine' like interface to generating a full city infrastructure system! Create a SketchUp parametric building modeler and you can develop set for model trains, virtual cities for the big screen and Real world studies for municipalities. Then export the whole thing component by component to a 3d printer and have a physical model to take to a municipal presentation for zoning! πŸ˜‰ This, my dear, is a real Sketchup game changer! Thank you for all the hours you spent on this! This should be voted as plugin on the month! Awesome! Sketchup: "The Next Big Thing". Can't wait to have fun with it! πŸ‘
                    • eneroth3E Offline
                      eneroth3
                      There seems to be some bug with the observers in older SU versions 😞 . However you can try it in Sketchup 2013. I've tried to make it as easy as possible to initialize own rolling stocks and it would be really fun if you and other people made your own and sharde πŸ˜„ . At the moment there's some strange bug when saving a rolling stock to the library so after doing so it's best to restart SU to avoid it from crashing later.
                      Oh 😲 , I thought it would break on web dialogs and possibly multiple document interface. I'll look into this error.
                      • OxerO Offline
                        Oxer
                        Thansk for the reply!!
                        This is a incredible plugin πŸ‘ , I would like play with it on Mac, waiting your fix. πŸ˜’
                          driven
                          @eneroth3 said:
                          Oh :shock: , I thought it would break on web dialogs and possibly multiple document interface. I'll look into this error.
                          on mac
                          File::ALT_SEPARATOR
                          nil
                          so it runs with PLUGIN_ROOT = File.dirname(__FILE__) unless defined?(self::PLUGIN_ROOT)
                          WebDialog needs a show_modal conditional for mac...
                          seems to work...
                          john
                          also, to see the docs...
                          menu.add_item("Documentation") { UI.openURL('file://' + (File.join(PLUGIN_ROOT, "ene_railroad", "docs", "home.html"))) }
                          PS. the track builds the trains run, speed works... very cool...
                          I'll have a closer look at the code on the weekend...
                          One question, why do you get/need the screen/window position/size?
                          • OxerO Offline
                            Oxer
                            Hi driven, I have changed the PLUGIN_ROOT in ene_railroad.rb and in the line for Documentation Menu (main.rb) and it works on Mac now. πŸ‘
                            I tested some features, not all, and for the moment they work but there are problems with the Add Rolling Stock window:
                            1. Library Tab --->You can't do scroll in the window, you don't type in the Filter input field and the default Stock is selected and fixed, you can't select another stock.
                            Library Tab
                            2. Create Tab --> The images of the steps don't appear and in the first step when you select a model to create the Rolling Stock the window goes to background.
                            Create Tab
                              driven
                              @oxer,
                              a temporary fix for the disappearing dialogs is to change all dialog.show to dialog.show_modal, I think there's 11 including the @dialog ones, I just used 'Text Wrangler' find and replace on the whole folder...
                              I'll have a look at the html and js tonight
                              john
                              • OxerO Offline
                                Oxer
                                Thanks driven for your help!!
                                I'll try that.
                                • N Offline
                                  nick9111
                                  I like to make different transportation zone models and I will play a lot with this plugin! If there will be a road and cars version it could just make me happy πŸ˜›
                                  • eneroth3E Offline
                                    eneroth3
                                    I have a quite big project in school right now so that's why I haven't been able to look into these bugs yet. I think I'll be more active here in a few dayss
                                      dacastror
                                      I have the following error
                                      I use windows 7 and tried this plugin in sketchup 8 and sketchup 2014
                                      • eneroth3E Offline
                                        eneroth3
                                        @driven said:
                                        @oxer,
                                        john
                                        I'm working on fixing these bugs now. Was the unresponsive rolling stock library fixed by making the dialogs modal or is that a different error?
                                        [attachment=0:2f896uym]<!-- ia0 -->error.jpg<!-- ia0 -->[/attachment:2f896uym]
                                        The plugin is not supposed to work in SU 8 but should in 2014. I cannot reproduce this error πŸ˜• .
                                        • DesertRavenD Offline
                                          DesertRaven
                                          Hi Eneroth, congratulations to to your plug in, this is amazing work. I also am a big fan of your other plug-ins for SU, they are Dynamite!.
                                          On a different note, do you know the Unity 3D gaming engine? I was wondering if you can write this plug in for the unity engine? I'd be interested in a script to run a train on a pre-defined track. Since this is looking pretty good on SU I'm sure a step up to Unity would be the sh.t.
                                          Anyway, great work!
                                          simplicity is the ultimate sophistication
                                            driven
                                            No, it's something to do with your 'selected' item never releasing focus to other selections...
                                            I had a quick look, but because your using a table, there wasn't an instant fix...
                                            I'll have another look and see if I can help with any further info,,,
                                            john
                                            I can't find what is generating this error???
                                            • 18
                                            • 19
                                            • 2 / 19
