    Report Generator - Imperial data exported from Metric Model
    3 Posts 2 Posters 1.4k Views 2 Watching
    • S
      smb5823
      Using SU2014Pro when I export a CSV format file from a Metric sketchup model, the resulting output is in Imperial.
      Not sure if this is a BUG or rather some setting I might have missed.
      • A
        Aerilius
        The model is not really "metric", but uses fingers, eh inches. The units setting only is about which units to display in the user interface. Sometimes this results in inches leaking through when they are not converted into your preferred units.
        I don't know if this could be the case with reports.
        • S
          smb5823
          Thanks for the quick response. Much appreciated. Will have to convert the imperial data into corresponding Metric then....
