    Layout file size with inserted jpg
    Scheduled Pinned Locked Moved LayOut Bug Reporting
    layout
    4 Posts 3 Posters 8.5k Views 3 Watching
    • K
      kaas
      In short: why does Layout convert inserted jpg's to png within a layout file?
      In the Sketchup docs http://help.sketchup.com/en/article/95640 I read: "use compressed image file formats such as JPEG and PNG".
      I noticed though, if I insert 2 jpgs, 2.64Mb + 1.79Mb the layout file jumps from 6Mb to 59.89Mb. If I rename the layout extension to zip and look inside I see two png files of 18.24Mb and 30.37Mb.
      What can I do to get a more smaller file size (besides converting the jps to really low resolution)?
      • M
        marcdurant
        Hi-
        You're the second person who has reported this issue. So far I haven't been able to reproduce the problem, so no fix yet. If you can send me a copy of your layout file for investigation it might be helpful.
        Thanks,
        Marc
        • K
          kaas
          @marcdurant said:
          Hi-
          Thanks,
          Marc
          Hi Marc,
          Thanks for looking into the issue. I just send you a pm with the download location of the layout file.
          Regards,
          Max
          • GMthompsonG
            GMthompson
            are you converting a pdf into a image file
            you can learn something everyday by paying attention
