    Keyboard - Alt for Plugins not working
    7 Posts 2 Posters 1.1k Views 2 Watching
    • U
      unearthed
      Hi, I've lost the ability to do alt pto get the plugins dropdown (all other menu dropdowns are working fine) - has anyone else had this and how did you solve it?
      Growplan - People ∩ Plants ∩ Place
      windows 7 64b, 4GB RAM, SU 8.0.16846
      Gimp, QGIS, Vectorworks 12, Bricscad 11
      • Dan RathbunD
        Dan Rathbun
        To find out what command is assigned to "ALT+P":
        (1) Open the Ruby Console.
        (2) type:
        puts Sketchup.get_shortcuts.find {|ks| ks =~ /\AAlt\+P\t/ }
        Then (3) open the Preferences dialog,
        (4) go to the Shortcuts panel,
        (5) navigate to the command that was displayed in (2) above,
        (6) highlight the "Alt+P" shortcut,
        (7) click the "-" button.
        Close the Preferences dialog.
        I'm not here much anymore.
        • U
          unearthed
          Hi Dan, when I put that string into console I get this returned -
          nil
          nil
          I get the same return if I enter swap in F for file
          • Dan RathbunD
            Dan Rathbun
            Just to be sure the find filter is not working.. let us list them all:
            puts Sketchup.get_shortcuts.sort
            .. and see if there is a command set for Alt+P ?
            • U
              unearthed
              Results from - puts Sketchup.get_shortcuts.sort [strange there's only one alt instance - my other alt shortcuts work - I reinstalled last week to see if I could get functionality back and still no change]
              A Draw/Arc
              Alt+Backspace Edit/Undo
              B Tools/Paint Bucket
              C Draw/Circle
              Ctrl+A Edit/Select All
              Ctrl+C Edit/Copy
              Ctrl+Insert Edit/Copy
              Ctrl+N File/New
              Ctrl+O File/Open...
              Ctrl+P File/Print...
              Ctrl+S File/Save
              Ctrl+Shift+E Camera/Zoom Extents
              Ctrl+Shift+W Camera/Zoom Window
              Ctrl+T Edit/Select None
              Ctrl+V Edit/Paste
              Ctrl+X Edit/Cut
              Ctrl+Y Edit/Redo
              Ctrl+Z Edit/Undo
              Delete Edit/Delete
              E Tools/Eraser
              F Tools/Offset
              G Edit/Make Component...
              H Camera/Pan
              I Camera/Image Igloo
              K View/Edge Style/Back Edges
              L Draw/Line
              M Tools/Move
              O Camera/Orbit
              P Tools/Push/Pull
              PageDown View/Animation/Next Scene
              PageUp View/Animation/Previous Scene
              Q Tools/Rotate
              R Draw/Rectangle
              S Edit/Item/FredoScale/Box Scaling
              Shift+Delete Edit/Cut
              Shift+F1 SketchUp/Context Help
              Shift+Insert Edit/Paste
              Shift+T Camera/Standard Views /Top
              Shift+Z Camera/Zoom Extents
              Space Tools/Select
              T Tools/Tape Measure
              Z Camera/Zoom
              nil
              • Dan RathbunD
                Dan Rathbun
                Next I would check your system wide keyboard accelerators for something set to ALT+P.
                • U
                  unearthed
                  Thanks very much Dan, That was it - I use a shortcut tool called Clavier and I'd set Alt P to do something specific, and I now see that with Clavier I can set limits on the extent of that system change.
