    Rounding a value for export with a ":" separator
    7 Posts 3 Posters 673 Views 3 Watching
    • IltisI
      Iltis
      Hello,
      I'm working on a plugin to export the 2D coordinates of the selected faces. (Okay, with big help from others, I'm newbie in Ruby)
      		  # Open a file for writing
      		  File.open(filepath, "w"){ |file|
      			selection = Sketchup.active_model.selection
      			# Get an array of faces that are in the selection.
      			faces = selection.grep(Sketchup;;Face)
      			faces.each_with_index{ |face, index|
      			  # Write a label for the face.
      			  file.puts("Face#{index+1}")
      			  # Get a transformation object that translates from model space to 2d space of the face.
      			  t = Geom;;Transformation.axes(face.vertices.first.position, *face.normal.axes).inverse
      			  # Write all vertices to the file.
      			  face.outer_loop.vertices.each{ |vertex|
      				# Get the point of the vertex and apply the transformation.
      				point = vertex.position.transform(t)
      				# Convert the coordinates
      				u, v = point.to_a.map{ |c| c.to_f }
      				# Write the coordinates to the file.
      				file.puts("#{u*25.4};#{v*25.4}")
      It works, but I have two problems to solve, can you help me?
      1 / The numbers close to zero are represented by scientific notation (1e-14), which I have problems to read the text file.
      See for example this export of a circle :
      Face1
      0.0;0.0
      6.81483474218631;51.7638090205041
      -9.02389274415327e-014;103.527618041008
      -393.185165257814;51.7638090205041
      -386.370330515627;-9.02389274415327e-014
      -366.390246014701;-48.236190979496
      -19.9800845009259;-48.2361909794959
      I think I could use the command "sprintf", but I don't know exactly how to write it.
      2 / I need to repeat the first point at the end (to close the outline) and I don't know how to properly store this value for reuse.
      Thanks for your help.
      Renaud.
      • TIGT
        Try u.to_mm etc on your 'inch' values, so the tolerance is preserved.
        Some of your small exponent numbers are in effect 0.0, at least as far a SketchUp's 3d geometry is concerned.
        Here are some examples with sprintf...
        For example:
        1.0.to_mm 25.4 1.0135056009.to_mm 25.74304226286 0.000135056009.to_mm 0.0034304226286 0.00001.to_mm 0.000254 0.0001.to_mm 0.00254 0.000000135056009.to_mm 3.4304226285999997e-06
        Then:
        sprintf("%.6f", 0.254) 0.254000 sprintf("%.6f", 0.00254) 0.002540 sprintf("%.6f", 0.0000254) 0.000025 sprintf("%.6f", 0.000000254) 0.000000
        • D
          driven
          I use the much cruder
          file.puts("#{(u*10000*25.4).to_i.to_f/10000};#{(v*10000*25.4).to_i.to_f/10000}")
          to return
          Face1
          0.0:0.0
          -3682.0:0.0
          -3682.0:-3138.9999
          0.0:-3138.9999
          • IltisI
            Iltis
            Hello TIG and driven. The solution of driven work good. Thanks a lot!
            My second problem is how to code the ********lines in Ruby :
                    ********* blnFirstPoint=true
                        ********* if blnFirstPoint=true then
                        *********    X1=u
                        *********    Y1=v
                        *********    blnFirstPoint=false
                        ********* end if
                       ********* file.puts("#{(X1*10000*25.4).to_i.to_f/10000};#{(Y1*10000*25.4).to_i.to_f/10000}")
            It's to close the faces (see the attached picture).
            Thanks,
            Renaud
            Non-closed export
            • TIGT
              if blnFirstPoint=**=**true then
              Note it is == and NOT = when you are testing a value
              • the = assigns the first reference to be the second value, while the == compares two values and returns true/ false in an if test...
              Also only use a Capital letter at the start of a Constant, and make your 'variables' starting with lower-case letter.
              So it's NOT X1= but x1= etc...
              • D
                driven
                the alternate approach is to build an array that includes the start point twice...
                   all_points = []
                           #add the first at the end as well...
                           all_points.push(face.outer_loop.vertices[0..-1]).push(face.outer_loop.vertices[0])
                           #then run your code
                            all_points.flatten.each{ |vertex|
                there are more elegant ways...
                john
                • IltisI
                  Iltis
                  OK, this works well :
                              begin
                  			  blnFirstPoint = true
                  			  first_point_u=0
                  			  first_point_v=0
                              if blnFirstPoint==true
                  				  first_point_u = u
                  				  first_point_v = v
                  				  blnFirstPoint = false
                  				end #if
                  			  file.puts("#{(first_point_u*10000*25.4).to_i.to_f/10000};#{(first_point_v*10000*25.4).to_i.to_f/10000}")
                  Thanks a lot! 😍
                  Renaud
