    UV Model Unwrapping Plugin?
    2 Posts 2 Posters 351 Views 2 Watching
    • R
      Ridie1389
      I understand that SketchUp has a single plane method of applying UV Coordinates; however, I can't seem to get them to be seamless and/or non-distorted on a rounded object. So I'm curious to know if there is some kind of plugin that creates a flat texture map of the model in question. Or if there is a way to use SketchUp's method more efficiently than that would also be greatly appreciated.
      Thank you!
      • M
        mwm5053
        You might want to watch this https://www.youtube.com/watch?v=HHsRRLCAOm8
        and there are several plugins around for UV mapping
        http://sketchucation.com/pluginstore?pln=tt_uv_toolkit
        http://sketchucation.com/pluginstore?pln=UVtools
        http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=57270
        2011 iMac
        SU 2015 Pro, 2017 Make
        V2 Twilight
        macOS Sierra 10.12.5
