    Nicedit for SketchUp (javascript issue)
    9 Posts 5 Posters 1.9k Views 5 Watching
    • inteloideI
      inteloide
      Hello Everybody,
      For one of my plugin, I would like to add a Rich Text area.
      I have seen that nicedit is a good javascript package to do this. Therefore I try to integrate it in SU.
      Nevertheless, I have some difficulties with the event management : it looks like it doesn't work...
      Has anybody already work with nicedit ?
      Here is the HTML page I want. Inside there is a textarea, converted by nicedit in Rich Text editor, but the event "key up" doesn't trigger at all...snifff
      <html>
      	<script type="text/javascript" src="../nicEdit.js"></script>
      	<script>
      		function start(){
      			var myEditor = new nicEditor({fullPanel ; true }).panelInstance('comments');
      			myEditor.addEvent("key", function() { alert('test') });
      			nicEditors.findEditor('comments').setContent(
      				'<a class="someclass" href="http://www.google.com">Click Here</a>'
      			$('.nicEdit-main').on('click','.someclass',function(){
      				alert('clicked');
      			$("div.nicEdit-main").keyup(function () {
      				alert('clicked');
      	</script>
      	<body onload="start();">
      		<textarea name="comments" id="comments" cols="40"></textarea>
      	</body>
      </html>
      And here are the nicedit files required (to be place in upper folder)
      nicedit
      Here you have an example to script working (See counter count down when key up)
      http://jsfiddle.net/jGLRn/15/
      In SU the event is not raised, as trapped by SU...
      Thank you in advance for your help.
      Inteloide
      Humanity will do a huge step when the IT professionals will understand that computers are tools...
      • jolranJ
        jolran
        Hi. Without testing any code... You might try attaching some meta tags to the HTML, if you havent done so.
        Something like.(for windows only)
        <meta http-equiv="content-type" content="charset=UTF-8" />
        	<meta http-equiv="MSThemeCompatible" content="Yes" />
        	<meta http-equiv="X-UA-Compatible" content="IE=edge>
        Your javascript library might require a later version of browser than what is automatically loaded from a default webdialog. I think it is reverted to IE8 ? Not lastest one installed.
        • inteloideI
          inteloide
          Hello Jolran,
          I try to add the meta tags, but it still doesn't work.
          I'm surprised that SU webdialog reverse back to IE 8, but I will try other tests in that direction...
          In any case, thanks for your answer.
          Inteloide
          • jolranJ
            jolran
            Ah, to bad. That's the only "quick" solution I could think of..
            I know nothing about NicEdit, can not comment on it's compability with Sketchup.
            I assume you are aware of webdialog focus and issues trapping keyevents ?
            http://sketchucation.com/forums/viewtopic.php?f=180%26amp;t=57462
            Maybe have a peek into Aerilius different consols, if you wish to solve this sans JS library.
            Can't have different color highlighting in a HTML text-inputfield though 😞
            BTW, this topic may get moved to the developper section...
              Moved
              • tt_suT
                tt_su
                Visual Studio Express is a nice tool to debug WebDialogs. Install Visual Studio and in your JS code add debugger; where you want to jump into the debugger where you can step through the code, inspect variables and see any exceptions raised.
                I think you also need to enable debugging in Internet Explorer advanced settings.
                • Dan RathbunD
                  Dan Rathbun
                  I think you need to declare the var in the global scope, outside the %(#8000BF)[start()] function.
                  <html>
                     <script>
                        var myEditor;
                        function start(){
                              alert('clicked');
                              alert('clicked');
                     </script>
                     </body>
                  </html>
                  I'm not here much anymore.
                  • Dan RathbunD
                    Dan Rathbun
                    Your keyup function is set to a DIV element of class "nicEdit-main", which does not exist in the example above (in the original post.)
                    • inteloideI
                      inteloide
                      Hello,
                      thank you for your answer.
                      Actually the main reason why it didn't work, is beceause jQuery was required. Once added, it work fine.
                      Inteloide
