    [Plugin] GKWare Stair Maker
    49 Posts 13 Posters 13.8k Views 13 Watching
    • G Offline
      Garry K
      Log on to my website and email me from there. I'll walk you through it.
      • G Offline
        garystan
        Hi everybody :
                           I tried running Stair Maker, Version 1.0.23, and I noticed that it didn't have the OKAY button.  Suggestions ?
        garystan
        • G Offline
          Garry K
          Stair Maker's current version is 1.0.32
          Are you sure you installed 1.0.23
          What does it say at the top of the form?
            db11
            Hi Gary -
            I'm wondering if you're planning on adding L and U-shaped stair options to this plugin? It would seem a relatively easy thing, especially compared to what you've already created for spiral stairs.
            I've been following your progress on Cabinet Maker, so I realize that you've likely not had a lot of time to devote lately to Stair Maker. It would be great if I could (eventually) use it for all the stairs I model — the majority of which are either U-shaped or L-shaped.
            Any word for future development for this one?
            • G Offline
              Garry K
              Doug - I do have plans to get back into StairMaker.
              L shaped and U shaped stairs are part of my plans (using simple landings). There will probably be additional parameters. I'm also thinking about including a notching point for either side of the stair. Example the top of the stair is between 2 walls and the stair widens after the notching point, possibly changing from housed to sawtooth after the notch.
              • G Offline
                Garry K
                Another idea that I have is to create elliptical stairs. There are essentially 2 types where the stair starts either at the minor or major axis. These stairs can be made comfortable without having a change of pitch. They can also be made with a continuous change of pitch (bigger challenge - more costly)
                  db11
                  That's great Gary — looking forward to seeing future Stair Maker development.
                  • K Offline
                    Kassul
                    Hey Gary K,
                    I justed download your "stair maker" plugin but i can't use it.
                    I'm register on your web site but an error message appears on up left corner of the control window "web service error code 101". You can see on the JPEG file.
                    thank you for your help.
                    • G Offline
                      Garry K
                      Error 101 means the internet connection time out on your computer. Stairmaker needs to connect to my web service once every week.
                      • 3 / 3
