    [Plugin] GKWare Stair Maker
    49 Posts 13 Posters 14.8k Views 13 Watching
      db11
      Just wanted to register my satisfaction with this plugin. I bought it to help me generate a set of half-spiral stairs for a client project.
      The plugin itself is well-done and works flawlessly. But what really impressed me is how well Garry K supports it. He has been tremendously helpful in showing me how to generate output from it that it was not specifically designed to do. (in this case a single central steel stringer)
      And with every query —and there were several in my case!— his replies were prompt and on-point. Really a pleasure to deal with.
      Highly recommended to anyone who needs to resolve a spiral stair conundrum.
      Doug
        Garry K
        Here are 2 more 2D stair videos.
        • KrisidiousK Offline
          Krisidious
          A man after my own heart... Curved Stairs Pro Style...
          By: Kristoff Rand
            Garry K
            Here are a few more videos:
            Flattening stringers for machining - CNC or by hand.
            Adding finished bottom to stair.
            Second method for adding a finished bottom.
              Garry K
              New version 1.0.32 now available for download
              • Version number now shows up on title bar of web dialog
              • Now uses same License strategy as cabmaker
              • Check license now first deletes old license and then updates license
              • Has preferred setting for users who have license issues
                garystan
                Sketchucation :
                                 I'm not sure HOW to install this add-on.  I'm running Sketchup 8.    garystan
                  Garry K
                  Log on to my website and email me from there. I'll walk you through it.
                    garystan
                    Hi everybody :
                                       I tried running Stair Maker, Version 1.0.23, and I noticed that it didn't have the OKAY button.  Suggestions ?
        garystan
                      Garry K
                      Stair Maker's current version is 1.0.32
                      Are you sure you installed 1.0.23
                      What does it say at the top of the form?
                        db11
                        Hi Gary -
                        I'm wondering if you're planning on adding L and U-shaped stair options to this plugin? It would seem a relatively easy thing, especially compared to what you've already created for spiral stairs.
                        I've been following your progress on Cabinet Maker, so I realize that you've likely not had a lot of time to devote lately to Stair Maker. It would be great if I could (eventually) use it for all the stairs I model — the majority of which are either U-shaped or L-shaped.
                        Any word for future development for this one?
                          Garry K
                          Doug - I do have plans to get back into StairMaker.
                          L shaped and U shaped stairs are part of my plans (using simple landings). There will probably be additional parameters. I'm also thinking about including a notching point for either side of the stair. Example the top of the stair is between 2 walls and the stair widens after the notching point, possibly changing from housed to sawtooth after the notch.
                            Garry K
                            Another idea that I have is to create elliptical stairs. There are essentially 2 types where the stair starts either at the minor or major axis. These stairs can be made comfortable without having a change of pitch. They can also be made with a continuous change of pitch (bigger challenge - more costly)
                              db11
                              That's great Gary — looking forward to seeing future Stair Maker development.
                                Kassul
                                Hey Gary K,
                                I justed download your "stair maker" plugin but i can't use it.
                                I'm register on your web site but an error message appears on up left corner of the control window "web service error code 101". You can see on the JPEG file.
                                thank you for your help.
                                  Garry K
                                  Error 101 means the internet connection time out on your computer. Stairmaker needs to connect to my web service once every week.
                                  • 3 / 3
