    3D scanned images for sketchup
    2 Posts 2 Posters 913 Views 2 Watching
    • ANBenderA
      ANBender
      Hello friends at Sketchucation,
      I am trying to scan some objects in 3D and then import them into Sketchup, using Cube's 3D Sense Scanner. I would like to keep the color of the 3D scan. I can export to STL PLY and OBJ . At this point I tried to import STL and it did not work the file size was 10 MB or so. I also tried a OBJ plugin and it started importing but also failed. Any advice. Thanks so much in advance.
      Bender β˜€
      • soloS
        solo
        Share the obj and mtl or other files and I will try converting it for you
        http://www.solos-art.com
