    Context Click Blip
    6 Posts 3 Posters 445 Views 3 Watching
      When I right click in the SU window I'm getting a beep on my PC. I'm guessing it is from a plugin installed or updated in the last few weeks. Is there a quick way to search via the Console for which plugin might be adding that beep? There have been quite a number of updates or new installs in the last few weeks so I'm not sure which of the newer installs to look at.
      • BoxB Offline
        Try house builder, that used to be the culprit.
          Man! Are you good. After reading your reply I remembered that from a long time ago. And I did recently install it after someone insisted it doesn't work in SU2014 which it does.
          Thank you sir.
            driven
            beat me to it , this may have found it
            find_beep = (Sketchup.find_support_files("", "Plugins")).grep("UI.beep")
            • BoxB Offline
              Just a lucky guess Dave, it was that recent housebuilder thread that made me think of it.
                Thank you, driven. I was hoping for something like that although it doesn't seem to turn up anything when Housebulder is active. I've disabled it in the Plugin Store tool and that gets rid of the annoying beeps.
                @Box, lucky guess or not, you hit the nail on the head.
