    [Plugin] MoveAlong - v1.2b - 07 Jul 14
    71 Posts 26 Posters 70.7k Views 26 Watching
      dedmin
      :tada:
      • PixeroP Offline
        Pixero
        Thats very impressive. πŸ‘
          rv1974
          Is it possible to replicate (via Ruby) the Max'2015 Placement Tools?
          The moving object temporallygets the 'gluing' feature, all environment temporally
          looses it's group\component structure (and thus becomes a set of primitive surfaces-receivers).
          • fredo6F Offline
            fredo6
            I believe this is doable.
            However, I think this should be in another plugin. The reason is that with Move, you match the origin point picked with a target. If you pick a point of the Component on its top, then the component will be flipped because the picked point will be moved to the underlying surface. So you'll see now the bottom of the component.
            The Place function is different and has more to do with detection of collision. The issue is that the top of a component may well be different from its bottom, and thus the Place function will not be accurate for the placement.
            Anyway, this is an interesting problem and worth exploring as this is missing in Sketchup.
            For the time being, I intend to publish an evolution of MoveAlong with Alignment features, as illustrated in the video below (probably next week as I take a few days off the computer):
            Fredo
              fredomax6 ! πŸ˜„
              • cottyC Offline
                cotty
                it's hard to wait any longer... πŸ‘
                my SketchUp gallery
                • fredo6F Offline
                  fredo6
                  NEW RELEASE: MoveAlong v1.2a - 18 Jun 14
                  MoveAlong 1.2 is an update fixing bugs and including:
                  • Alignment mode (useful for preparing a Follow me or chaining curves)
                  It is published as part of FredTools 2.0a.
                  See main post of this thread and FredoTools for download.
                  Fredo
                    dedmin
                    See the animated gif:
                    • fredo6F Offline
                      fredo6
                      @dedmin
                      2 questions:
                      1. on the problem with MoveAlong, I am unable to reproduce it. Can you reproduce it. If so, do you mind to post or PM me the model with the 2 arcs. Can you also open the Ruby console while you perform the move. Thanks
                      2. your set up seems to have a larger font size for the text drawn in the viewport (this is visible in the button palette). Did you tweak anything in the configuration parameters?
                      Fredo
                        dedmin
                        Here is the sample file with arcs, circle and freehand drawn curve. Nothing shows in the Ruby console when using the plugin. The large font size is due to the Windows 7 64 bit settings - Display - Set custom text size (DPI) - 125%.
                        Thanks.
                        move_along.skp
                        PP: I noticed something - when turning on Edge styles - Profiles the missing edges are visible!
                        • fredo6F Offline
                          fredo6
                          Thanks dedmin for signaling this problem.
                          I found the cause and fixed it. Edgges resulting from the intersection of the 2 arcs are set with smooth and soft properties. This is an (undesired) side effect of the autosmooth feature.
                          This will go in a next release
                          Fredo
                          • fredo6F Offline
                            fredo6
                            NEW RELEASE: MoveAlong v1.2b - 07 Jul 14
                            Movealong 1.2b is an update fixing a bug signaled by dedmin
                            It is published as part of FredTools 2.0b.
                            Fredo
                            • pep75P Offline
                              pep75
                              I've a problem...I checked all your instruction movies, but can't find a solution. When I want to move lines or faces in one active group I cannot snap or interfere with objects outside the active group. Am I missing something?? I installed the latest version...
                              Thanks in advance....
                                Seems normal : you copy move something froma group πŸ˜‰
                                Just don't you use the plug in this particular case!
                                and you will have a perfect allignement inferencing with any thing ! πŸ˜‰
                                Generally a copy/move is the trick for have a direct inference with something! πŸ€“
                                • pep75P Offline
                                  pep75
                                  Hi Pilou,
                                  You actually don't need the plugin anyway. But that's not the issue. I only noticed that snapping to other objects, while in a group, is not possible...while it is possible when you ungroup the object. I would like to know if it is me being stupid...or that I have to switch between the "original" move function and MoveAlong(which I prefer in MOST cases).
                                  • fredo6F Offline
                                    fredo6
                                    This is a limitation of the Ruby API. When you are inside a group or component, it is not possible to see the outside model. The same happens for MoveAlong or DrawAlong
                                    As recommended by Pilou, you need to switch to the native Move tool to be able to use inferences outside the group context.
                                    Fredo
                                    • pep75P Offline
                                      pep75
                                      Thanks Fredo....it's a pity...But thanks nevertheless!
                                      • fredo6F Offline
                                        fredo6
                                        I may try to find a workaround, but this requires some thoughts first.
                                        Fredo
                                        • pep75P Offline
                                          pep75
                                          Hahaha! Okay! I'll wait patiently for a brilliant moment! πŸ˜‰!
                                            Manuelrql
                                            IΒ΄m beginning to use the command move along instead of the normal move. But when IΒ΄m copying objects using ctrl and try to relocate them in my model using pan (mouse central button & shift) the move along command does a copy of the object at the first point that I pick in the model to grab with the pan hand.
                                            Has this happened to any one else?
                                            • 3 / 4
