    [Plugin] MoveAlong - v1.2b - 07 Jul 14
    71 Posts 26 Posters 74.8k Views 26 Watching
      dedmin
      1. Pick a component's insertion point when moving.
      2. Move a perpendicular to a curve - grab a center of a face and move it perpendicular to a curve.
      Thanks.
      • fredo6F
        Thanks.
        This is coming
          dedmin
          :tada:
          • PixeroP
            Pixero
            Thats very impressive. πŸ‘
              rv1974
              Is it possible to replicate (via Ruby) the Max'2015 Placement Tools?
              The moving object temporallygets the 'gluing' feature, all environment temporally
              looses it's group\component structure (and thus becomes a set of primitive surfaces-receivers).
              • fredo6F
                I believe this is doable.
                However, I think this should be in another plugin. The reason is that with Move, you match the origin point picked with a target. If you pick a point of the Component on its top, then the component will be flipped because the picked point will be moved to the underlying surface. So you'll see now the bottom of the component.
                The Place function is different and has more to do with detection of collision. The issue is that the top of a component may well be different from its bottom, and thus the Place function will not be accurate for the placement.
                Anyway, this is an interesting problem and worth exploring as this is missing in Sketchup.
                For the time being, I intend to publish an evolution of MoveAlong with Alignment features, as illustrated in the video below (probably next week as I take a few days off the computer):
                  fredomax6 ! πŸ˜„
                  • cottyC
                    cotty
                    it's hard to wait any longer... πŸ‘
                    my SketchUp gallery
                    • fredo6F
                      NEW RELEASE: MoveAlong v1.2a - 18 Jun 14
                      MoveAlong 1.2 is an update fixing bugs and including:
                      • Alignment mode (useful for preparing a Follow me or chaining curves)
                      It is published as part of FredTools 2.0a.
                      See main post of this thread and FredoTools for download.
                        dedmin
                        See the animated gif:
                        • fredo6F
                          @dedmin
                          2 questions:
                          1. on the problem with MoveAlong, I am unable to reproduce it. Can you reproduce it. If so, do you mind to post or PM me the model with the 2 arcs. Can you also open the Ruby console while you perform the move. Thanks
                          2. your set up seems to have a larger font size for the text drawn in the viewport (this is visible in the button palette). Did you tweak anything in the configuration parameters?
                            dedmin
                            Here is the sample file with arcs, circle and freehand drawn curve. Nothing shows in the Ruby console when using the plugin. The large font size is due to the Windows 7 64 bit settings - Display - Set custom text size (DPI) - 125%.
                            Thanks.
                            move_along.skp
                            PP: I noticed something - when turning on Edge styles - Profiles the missing edges are visible!
                            • fredo6F
                              Thanks dedmin for signaling this problem.
                              I found the cause and fixed it. Edgges resulting from the intersection of the 2 arcs are set with smooth and soft properties. This is an (undesired) side effect of the autosmooth feature.
                              This will go in a next release
                              • fredo6F
                                NEW RELEASE: MoveAlong v1.2b - 07 Jul 14
                                Movealong 1.2b is an update fixing a bug signaled by dedmin
                                It is published as part of FredTools 2.0b.
                                • pep75P
                                  pep75
                                  I've a problem...I checked all your instruction movies, but can't find a solution. When I want to move lines or faces in one active group I cannot snap or interfere with objects outside the active group. Am I missing something?? I installed the latest version...
                                  Thanks in advance....
                                    Seems normal : you copy move something froma group πŸ˜‰
                                    Just don't you use the plug in this particular case!
                                    and you will have a perfect allignement inferencing with any thing ! πŸ˜‰
                                    Generally a copy/move is the trick for have a direct inference with something! πŸ€“
                                    • pep75P
                                      pep75
                                      Hi Pilou,
                                      You actually don't need the plugin anyway. But that's not the issue. I only noticed that snapping to other objects, while in a group, is not possible...while it is possible when you ungroup the object. I would like to know if it is me being stupid...or that I have to switch between the "original" move function and MoveAlong(which I prefer in MOST cases).
                                      • fredo6F
                                        This is a limitation of the Ruby API. When you are inside a group or component, it is not possible to see the outside model. The same happens for MoveAlong or DrawAlong
                                        As recommended by Pilou, you need to switch to the native Move tool to be able to use inferences outside the group context.
                                        • pep75P
                                          pep75
                                          Thanks Fredo....it's a pity...But thanks nevertheless!
                                          • fredo6F
                                            I may try to find a workaround, but this requires some thoughts first.
                                            • 3 / 4
