    Layout - Angular Dimensions True to Model
    layout
    2 Posts 1 Posters 969 Views 1 Watching
    • TandemT
      Tandem
      Is it possible to have Layout base Angular dimensions on the actual angles of the model?
      When I add an Angular dimension to a page in Layout the angle is measured based on the lines on the Layout page not of the model. Linear dimensions seem to work correctly.
      Am I missing some settings or is this a limitation of the current version of Layout?
      Sketchup / Layout Version 14.0.4899 OS X
      Thank you in advance.
      • TandemT
        Tandem
        I reported this issue to SketchUp and they confirmed that angular dimensions are only respecting Paper Space and not Model Space.
