    Cross domain testing with ajax and JSONP
    7 Posts 4 Posters 1.0k Views 4 Watching
    • G Offline
      Garry K
      I've been asked to start a new thread by the Extension Warehouse on an issue that several of us were trying to nail down back in February.
      It has to do with not being able to connect to a web service because of Cross Domain policy.
      We tried this on SU 7, SU 8, SU 2013 and SU 2014 with Windows 7 and it worked using XMLHttpRequest and Javascript.
      However it failed to connect with OSX Lion. Mavericks worked.
      The thread was: viewtopic.php?f=180&t=56262
      I am now testing JQuery, ajax and JSONP for cross domain connectivity.
      dialog_test_5.rb
        driven
        Your name is Jeff Hansen
        I assume that's expected...
        you got you show and show_modal about face, btw...
        john
        • G Offline
          Garry K
          Yes that is what I expected.
          Which OS did you test?
            driven
            same as usual... mac
            it's all I own...
            not convinced I like having user details hidden behind the info button...
            and mavericks...
            john
            • Dan RathbunD Offline
              Dan Rathbun
              @driven said:
              ... you got you show and show_modal about face, btw...
              In the US we say "butt-backwards" šŸ˜›
              I'm not here much anymore.
                You could also try a simpler GET, rather than a convoluted POST ?
                Like:
                $.ajax({
                  type ; 'GET',
                  url  ; 'HOST',
                  data ; {"firstname"; "Jeff"},
                  crossDomain; true,
                  timeout; 10000,
                  success; function(data) {
                    // your success msg using data arg
                  error; function (jqXHR, textStatus, errorThrown) {
                    // your failure msg using potentially 3 args
                • G Offline
                  Garry K
                  I was hoping to do a POST because I will be updating a database with my real JSONP call.
                  Unfortunately when I do a check on the php side I see that the call is turned into a GET.
                  I agree that a timeout and an on error function is a good idea.
                  My main question is will this work with OSX Lion. I was hoping that someone could try it out and tell me.
