    How to fetch all material in SKP via Ruby?
    2 Posts 2 Posters 365 Views 2 Watching
    • R
      rahulnejanawar
      Is it possible to fetch all material items which are appear in the Sketchup materials window by ruby?
      Is there any function which do the above work ie which can access the all items(material type) in the Materials?
      I found that the below function which works for Model-
      model = Sketchup.active_model
      matrials = model.materials
      materials[0].name ==> gives name of the material
      Like this above any other function by which we can retrieve the all Material items which are present in Sketchup Materials(class index).
      • TIGT
        You can only access the Materials that are loaded into the Model.
        You can iterate the list and get various aspects of the material.
        Sketchup.active_model.materials.each{|material|
          puts material.name
          puts material.display_name
          puts material.color
          puts material.alpha
          puts material.texture
          ### and so on...
          puts
        I have included the puts so the info is shown in the Ruby Console but of course you can do other things with that...
        A Material's '.display_name' is not always the same as the '.name' [depends on its creation/source]
        A Texture can also be further probed to get info like its image, size and so on...
        Read the API http://www.sketchup.com/intl/en/developer/docs/classes.php
        If you must get details of SKM files not yet loaded [and not loadable using native API methods] then you could look at my SKMtools which offer many additional tools to import/export/interrogate SKM files etc...
        But please learn to walk before you run πŸ˜‰
