    Vray Animation Camera Shake
    extensions
    2 Posts 2 Posters 3.1k Views 2 Watching
    • E Offline
      eugatr
      Hello Guys!!
      I've been messing around with the vray animation thingy, and while I do get all the images rendered according to the scenes, when stitched together the camera... um... shakes...
      the scene animation on sketchup (pre render) seems pretty smooth but somehow after rendering it looks like if the video was recorded by someone with parkinsons disease 😞
      anybody knows how to solve this?
      thanks a bunch!
      • andybotA Offline
        andybot
        @eugatr said:
        Hello Guys!!
        thanks a bunch!
        How are you generating your animation path in Sketchup? Some animation plugins will generate hundreds of SU scenes - the problem with rendering that, is if the frame rate is not 1 to 1, then the rendering program will extrapolate the transition between the frames based on the SU movement, so you'll get a very jerky video. Try generating your animation scenes at the full frame rate, and then when you render with vray, set your fps rate to custom rate of "1"
        Hope that helps.
        Andy
