    [Plugin] Curve Maker, Taper Maker and Stock Maker updated
    1 Posts 1 Posters 520 Views 1 Watching
    • M
      max-cx
      The Curve Maker, Taper Maker and Stock Maker have all been updated to version 1.4
      The plugins are now compatible with SU 2014 and backward compatible with SU 2013 and SU 8.
      Most of the changes are bug fixes. The only thing "new" is that they are now distributed and installed independently of each other. So, for example, if you only use Curve Maker, then you need only download and install that one plugin.
      If you have installed versions 1.3.6 or earlier of the plugins, you need to DELETE THE FOLLOWING FILES from SketchUp's plugin folder prior to installing the latest version:
      ctsMaker (a folder - delete the folder including all of its contents)
      curve_maker.rb
      taper_maker.rb
      stock_maker.rb
      Thanks to Rich O'Brien's efforts, they are now available through the SketchUCation Plugin Store.
      They are also available at: http://www.drawmetal.com/download
      Terry
