    U can TEACH me?
    38 Posts 6 Posters 2.9k Views 6 Watching
    • architexA Offline
      architex
      @jeff hammond said:
      the way i think it should be is more along these lines:
      (drawn in rhino)
      [attachment=0:xhhhn40c]<!-- ia0 -->ellipse_dome1_.jpg<!-- ia0 -->[/attachment:xhhhn40c]
      [attachment=1:xhhhn40c]<!-- ia1 -->ellipse_dome2.jpg<!-- ia1 -->[/attachment:xhhhn40c]
      is that how you want it to look?
      Can RHINO draw equal segments (specific measure and dimension of that segments) at the half of an ellipse?
      And ask RHINO to draw its perpendicular intersection in the elliptical arch?
      Like you did on to have that structure frames perpendicular in elipse?
      • architexA Offline
        architex
        Here are the TEST! with its references.
        I post the specific image with specific dimension (meters) and the SKETCHUP FILE...
        U can teach me?
        Thanks for you comprehension.
        πŸ˜„
        ELLIPTICAL NOSE DOME.skp
        • jeff hammondJ Offline
          jeff hammond
          yeah, rhino can equally divide an ellipse or partial ellipse (or any curve) into a desired amount of segments or divide it up into lengths the user defines.. (i.e.- if i want to split an ellipse into 1m segments, that's possible)..
          then yeah, you can draw perpendicular lines to or from the curve at any given point.. or orient objects perpendicular to a curve etc.. actually, all sorts of things you can do in rhino in these regards-- too many to list here πŸ˜‰
          idk, you can draw radius type stuff in sketchup which is accurate and doesn't require too many workarounds/gymnastics from the user.. once you go beyond radii though (such as this ellipse structure), sketchup isn't the right tool to be using (imo)
          for instance, the end of this thing is sort of similar to the shape you're working with (except the ellipse is opposite-- snub nosed instead of pointy nosed) and there's no way i could of done it in sketchup.
          dotdotdot
          • architexA Offline
            architex
            I think, after finish my thesis and complete the architecture student moment, I will find a course to learn RHino...
            I really love sketchup. It fast to do some fast work. But I think when it come the day when we need to draw and intersect complex shapes, Sketchup loose a lot.
            I have been looking to Rhino, but I haven't get much time to spend on it and learn with some tutorial beginners.
            Perhaps, the Sketchup company could do A BETTER SKECTCHUP, and prepare it to do more accuracy forms.
              jeff hammond
              U can teach me?
              πŸ˜„
              here's a .skp which is an export from rhino using those dimensions with perpendicular lines drawn at the divide points..
              ellipseDome.skp
              it's a very fast process to draw this type of stuff in rhino but it took a few years for me to get to that point.. i really don't know how to explain a method to draw it in sketchup because most of the work will need to be done on a calculator and i don't know the formulas for drawing lines perp.to.ellipses..
              i don't know.. i used to wish sketchup was 'better' when dealing with curves or that it had a lot more features etc.. i basically used to wish sketchup would turn into rhino πŸ˜„
              but now, after spending the time to learn rhino, i'm glad sketchup is sketchup and rhino is rhino.. the both offer things which the other doesn't have and i'm not sure if it would work out right if they were both smashed into a single application.. but yeah, start learning rhino (or some other nurbs type app) when you find the time.. it's good to know more than one drawing program (imo)
              dotdotdot
              • architexA Offline
                architex
                Thank JEFF... you are the best.
                But can I ask you, for you to draw the same, more 2 examples?
                You made it with 4 spaces between, in which 4 + 4, total 8 spaces segments.
                Can you draw the same with:
                5 + 5 segment spaces? and other one with 6 + 6 segments?
                I think that would help me to decide some dimension when I draw the up level floor, and manipulate de spaces between de structure frame (to draw holes in the dome)
                Can you do that for me... And I think I found some material that help me determine the FOCUS point (FOCI) of the ellipse, and then draw perpendiculars to the arch in sketchup.
                One more time...
                You Rock dude.
                Thanks a lot.
                BIg hug men! πŸ˜„ 😍 😍
                • architexA Offline
                  architex
                  Ups! sorry.. I forget to say...
                  Let me correct... The main objective is to draw equal segments, starting at the minor axis (the one parallel to front view) WITH 2.40 meter (that`s the exactly dimension I need).
                  And if in the "nose" results with a different dimensions, there is no problem. Because that's the centre, and there are a main entry under the dome (like a FOYER entry, before going to the show room)
                  πŸ˜„
                  • architexA Offline
                    architex
                    Please, save it in SKETCHUP 2013, or SKETCHUP 8....
                    The file you give to me is in SKP 2014 version ... It`s impossible to open newer versions on earlier one.
                      jeff hammond
                      here it is in v8.. i usually remember to do that but... πŸ˜‰
                      ellipseDome_v8.skp
                      dotdotdot
                        jeff hammond
                        πŸ˜„
                        like this?
                        (note- last segment is 1.75m instead of 2.4m)
                        2_4m.skp
                        if this is right, i'll do one with the surface included.. the vertices along the ellipse of the other one i uploaded won't match up with these ones. (it's sometimes tricky dealing with nurbs surfaces which have been converted to meshes.. it's best to have everything joined up in the nurbs app prior to meshing.. that will allow all the vertices to match between the different parts)
                        [going to sleep soon.. leave a note if this version is right and i'll post another version in the morning]
                        dotdotdot
                          You can also try the little brother of Rhino
                          "Moment of Inspiration" a little more easy to learn! πŸ˜‰
                          (Ctrl + C, Ctrl + V is possible in the 2 ways between Moi and Rhino !!! )
                          You can use the demo infinite without save! β˜€
                          Some sufficient for have the distances! πŸ˜‰ A sort of super 3D Geometric drwawer tool! 😎
                          Here you propagate a point on the arc elllipse as you want then draw your Perpendicular lines by hands (helpers Lines are terrific )
                          all that take maybe 10 seconds! πŸ˜„ it's one of your ellipse!
                          http://s6.postimg.org/l7hdcv2dt/ellipseperp.jpg
                          • architexA Offline
                            architex
                            that right...yupi, yupi! πŸ˜„
                            You are the boss.
                            Thanks one more time.
                            • architexA Offline
                              architex
                              Hello there...
                              Thanks for answer and try to help. I have to say that I never had notice about that software. I will find out more about it... Can you say to me if it is possible to export to SKETCHUP, or AUTOCAD?
                              And about the trial version? Do I have 7 day for testing or no? In trial version still possible to export, save or something like that?
                              best greetings
                              • architexA Offline
                                architex
                                like this?
                                [attachment=1:h1ktb1n9]<!-- ia1 -->2_4m.skp<!-- ia1 -->[/attachment:h1ktb1n9]
                                [attachment=0:h1ktb1n9]<!-- ia0 -->2_4m.jpg<!-- ia0 -->[/attachment:h1ktb1n9]
                                [going to sleep soon.. leave a note if this version is right and i'll post another version in the morning][/quote]
                                That`s right bro...yupi, yupi! πŸ˜„
                                You are the great boss here.
                                Manny manny Thanks you, one more time.
                                It doesn't metter if the end close are different then 2,40meter measure. It have to be. Other wise, I have to calculate and redraw all ellipse to find every 2,40meter in equal segments.
                                ..I am gone open your SKP file this time, to see if the version save is ok.
                                Will contact to you soon.
                                If I leave EUA, or were you leave, I will buy you a drink my friend. You are priceless
                                πŸ˜„
                                  jeff hammond
                                  ha.. i like messing around with these types of structures so i get some fun out of doing it.. but yeah, if you're ever in nyc, i'll have a jack & ginger πŸ‘
                                  here's the version with the 2.4m layout and a domed surface with matching vertices.. good luck with the rest of your project.
                                  2_4withsurface_v8.skp
                                  dotdotdot
                                    A month ! πŸ˜‰ And of course yes you can save load anything! πŸ˜‰
                                    Absolutly sure for Sketchup πŸ˜„
                                    For AutoCad I have never try because I have not Autocad! πŸ’š
                                    Some colors on the Jeff's file πŸ˜„ A paragliding, parachute ? πŸ˜„
                                    • architexA Offline
                                      architex
                                      HELLO People.
                                      I have to say that i have been working on my structure. But everyday pass I find more troubles! shit for it!
                                      I am start to think that I miss some points.
                                      First I was working with MOI software (lovely and simple). Therefore I star learning RHINO (like in one week)... just about to love that software.. BUT my structure still having troubles.
                                      The last perpendicular to x plane (parallel to y plane) doesn't touch on the others frames. And because of that it is getting impossible to draw the oval shape.
                                      I make an array by the elliptical path.. everything went nice beside that last perpendicular frame. The problem are in that last arch curve. And I can not find the solution for it.
                                      ALL FINAL TRELLIS
                                      Hiding edges - show elliptical silhouette for shape construction
                                      • architexA Offline
                                        architex
                                        the only solution I was able to find, it was using/drawing 2 ellipses.
                                        1ΒΊ draw in X plan
                                        2ΒΊ draw in high in Y plan
                                        3ΒΊ revolve or loft.
                                        but in this solution I get an ugly regular elliptical shape.
                                        • 2 / 2
