    Fishing net modeling
    131 Posts 12 Posters 17.3k Views 12 Watching
    • W Offline
      willipop
      Now I will use the select brush and select every faces that show less vertex. Afterthen I will subdivide these faces to have a more uniform mesh. I'd like to have 10-15cm in between each edges.
        Nice bridge! โ˜€
        A Firenze revival? ๐Ÿ˜‰
        http://www.pintoresfamosos.cl/obras/galeria/bellotto.jpg
        PS Ruby not rugby! ๐Ÿ’š
        • W Offline
          willipop
          En Gaspรฉsie au Quรฉbec mon ami !
            Arf, je ne connais que Chicoutimi de nom รฉtant un vieux fan de Carole Laure! โ˜€
            http://nsm08.casimages.com/img/2014/02/13/14021310370316176911979249.jpg
            • olisheaO Offline
              olishea
              Your work is really coming on! Great stuff!
              oli
              • W Offline
                willipop
                Thx oli ๐Ÿ˜„ It's getting better ! I'm wondering how I will do the rendering !:)
                • W Offline
                  willipop
                  Itteration 4 makes perfect distance in between the edges ::):)
                  • olisheaO Offline
                    olishea
                    Good luck turning the lines to tubes! ๐Ÿ˜†
                    oli
                    • W Offline
                      willipop
                      its going to take approximately 36h ๐Ÿ˜ž:(:( both of my pc running on 2 different files. Jeez ! Hope i will be able to navigate in the file ^^
                        And what about junctions of tubes ? ๐Ÿ˜‰
                        Normally Lines2tubes don't managed them! ๐Ÿค“
                        • olisheaO Offline
                          olishea
                          I don't think it's possible to even see the junctions because the thread is so thin. What is your solution Pilou? ๐Ÿ˜‰
                          oli
                          • olisheaO Offline
                            olishea
                            Nope! ๐Ÿ˜†
                            oli
                              If you want really ropes maybe only lines are sufficient (hide faces) or to map a transparent texture ๐Ÿ˜„
                              But I am not sure that the drawing of lines shown is the real one in reality?
                              http://sketchucation.com/forums/download/file.php?id=117797&t=1
                              • W Offline
                                willipop
                                Yes I have to show lines in reality ! I'd like to have the shadow casted too ! ๐Ÿ˜„ I think I will have to try with png texture or transparent texture ... I know that I can make shadow visible from the edges in sketchup but I'm sure if it'll work in kerkythea or artlantis on the rendering.
                                • W Offline
                                  willipop
                                  Is there a way to apply a texture and have the shadow from the edges without doing to seperate rendering ?
                                  • mitcorbM Offline
                                    mitcorb
                                    I think TIG's Image Trimmer cuts away the transparent portions of a texture?
                                    • BoxB Offline
                                      You are running into the problems I mentioned way back with regard to file overload. While I like and can see benefits in using artizan I don't think it works for what you want.
                                      It depends on what you really want but to me it doesn't produce a flowing net properly, it's too round and not a uniform construction. Nets are very regular in their form and are affected and controlled by tension and gravity.
                                      Going back to the component method using tig's extrusion tools, this net is made from one component. The shape is very controllable, the size and position of the weave is easily changed by adjusting the nodes on the lines. Converting to tubes takes seconds. The file is 2.6mb, it can be navigated easily, slight lag with shadows turned on. Took a few minutes to make and renders in minutes.
                                      Drawing out the overall support pylons and wires would give you most of the construction lines needed. But it may not be the style you want.
                                      • olisheaO Offline
                                        olishea
                                        That looks awesome box!!!!
                                        Only issue is it's more angular than the photo...but to me it looks better, almost like it's creased into that shape when it's been hung.
                                        How do the nets meet? Can you post a close-up?
                                        With regards to texturing, I wouldn't bother if you can simply use the geometry effectively. Using 4 iteration of artisan is too much in nearly all cases and then adding tubes will completely freeze sketchup.
                                        oli
                                        • BoxB Offline
                                          I can give you the model.
                                          It's very quick, with a bit of work you could make something very detailed and neat. They don't actually join, I just made them straight along the edge so I could butt them together.
                                          By making ones that fit to the support pylon on one side and are straight on the other you can put a bunch together and still only use a few components.
                                          I wanted to create a quick version that showed the drape and tension but retained a relatively small file size.
                                          I think I saved this version as SU8, if I remember correctly you are still in the past.
                                          Net Drape1.skp
                                          • W Offline
                                            willipop
                                            It looks amazing ! It's white just like I imagine it ๐Ÿ˜„ Is this a texture or it's lines converted to tubes ?
                                            The problem is I can't use tig's extrusion tools, each time I'm having hard time, there's something I don't understand with this plugin... ๐Ÿ˜• can you upload the file Box ? Very nice job !
                                            • 6
                                            • 7
                                            • 4 / 7
