    Import cameras from 3DS file ?
    4 Posts 3 Posters 872 Views 3 Watching
    • D
      Dimethil
      Hi everybody.
      I'd like to import all cameras (scenes), from a 3DS file. How can I do that ? When I import the file in sketchup8, I only get the geometry... But when I open it in MAX, I can see all the cameras...
      I'm working on files with dozens of cameras, and I don't want to set them one by one... Is it there a plugin, or something else that could help ?
      nb : the 3DS file was saved from an archicad16 3D model.
      Thank you
      • J
        Jim
        I sent a plugin to your inbox - let me know if it works. If not, post it here and maybe someone can fix it, or wait until this afternoon. (I made it quickly before work.)
        • D
          Dimethil
          Thank you for your answer.
          I made some trys with your plugin, but it looks as if it if confusing inches and meters while importing the camera... I sent you more details in a private message 😄
          thanks again
          • C
            cleblanc
            Jim,
            Is the plugin you mentioned for importing cameras with a 3ds file available for download?
            Thank you
