    [Plugin] Add Layer [1.1.0]
    58 Posts 23 Posters 17.4k Views 23 Watching
    • J
      Jim
      For discussion of Add Layer plugin.
      v 1.1.0 Apr 10, 2014
      • Added ability to modify layers.
      v 1.0.1 Mar 24, 2014
      • Bug fix release.
      • utilerU
        utiler
        Instant gold, Jim! I don't know how many time I've been working on a complex model with multiple scenes and when I add a new layer for the scene I'm working on then have to go back through each and every scene to turn it off... this'll be a big time saver!!
        Am I right in saying its been a while since you've publishes a script???
        πŸ‘
        Just Curious...
        • O
          otb designworks
          Awesome! Any way to change the layer behavior after it has been created?
          For instance, if I make a layer and choose for it to be hidden for new scenes, but then I change my mind and want it visible for new scenes, is that possible to change?
          thanks!
          Cheers, Chuck
          OTB Designworks is on Youtube
          • jiminy-billy-bobJ
            jiminy-billy-bob
            πŸ‘
            Maybe add an option to choose the color in SU2014?
            • D
              db11
              thanks!
              Not sure from within this plugin, but the VisMap plugin is invaluable for managing scene/layer visibility:
              [Plugin] VisMap 2 - Improved Layer/Scene Visibility Map by MartinRinehart
              http://sketchucation.com/forums/viewtopic.php?t=23029
              It populates a layer/scene matrix and allows you to see in one glance which layers are set to visible in what scenes -- and allows you to toggle visibility across all scenes / layers. Not sure if it's 2014 compatible as it was last updated in 2009.
              I'm using it in SU8 and it works perfectly.
              • JQLJ
                JQL
                Uhh... So many layers of information between you two J's...
                Jiminy, I know it seems I'm stalking you but what if your "new layer" icon would be able to launch this plugin if we choose it to on preferences?
                Actually both plugins look good together too...
                Would you guys mind?
                www.casca.pt
                Visit us on facebook!
                • T
                  TECHDAVE02
                  There add scenes layer that works / on only that scene or you can update it to work in other scenes works well for dimensions http://sketchucation.com/forums/viewtopic.php?f=10%26amp;t=36583
                  Error 404 (Not Found)!!1
                  (sketchuptips.blogspot.ca)
                  • jiminy-billy-bobJ
                    jiminy-billy-bob
                    Haha, you're reading my mind. I was thinking about something like this today: Maybe replace the buttons in the menu that pops up when you hold-down click on the add-layer button in Layers Panel, by one that opens Jim's plugin if it's installed.
                    http://i.imgur.com/yKpZ3ZY.png
                    Jim, would you be okay with this?
                    • J
                      Jim
                      πŸ‘
                      Thanks, utiler. This extension is really an upgrade to my old "add hidden layer" plugin from back in 2007. But instead of me deciding what layer behavior you need, you get to choose.
                      Much of the credit goes to Thomthom for his SketchUp UI code. The code for adding the layer is about 25 lines of code. The other 2500 lines are for the user interface. In the past, UI for extensions was a real barrier to their creations. Recently, this barrier has been falling.
                      It has been a number of years since I have released a plugin, although I have been hacking on a few of the SketchUp Community Extensions on GitHub.
                      And with the SketchUcation Plugin Store making so much easier for people to upgrade, I hope to continue upgrading some of my old plugins.
                      • J
                        Jim
                        I don't mind, but I really think you should implement this in Layers Panel natively, rather than call my plugin. You should try to keep your interface consistent. Then, maybe add a separate LP sub-menu-item for "add a new layer" for people who who want to add a Layer without opening the main LP dialog.
                        I have Layers Panel installed, and know for a fact you would do a better job with the user interface than I can. πŸ˜„ Besides, you likely have most of the functions already in your code.
                        • jiminy-billy-bobJ
                          jiminy-billy-bob
                          Something like this, then? (With credit to you, obviously!)
                          http://i.imgur.com/q5SdJiH.png
                          • tt_suT
                            tt_su
                            Note that in SU older than 2014 creating layers with the special flag might cause SU to trigger the Fix Model dialog. That warning is a bug - nothing was messed up, it was the validation code that was wrong. And the Fix Model dialog will reset the flag unfortunately.
                            • N
                              Nortti
                              Thank you for the 'Add Layer' plugin! This is a huge time saver. Although, when I select "Layer visible on selected scene only" it does not create a layer. Am I missing something? Still even without this feature it's a success.
                              Thanks for any help in getting this fully working.
                              Mac OSX 10.9.2 / SketchUp Pro 2013
                              • J
                                Jim
                                You should get a dialog if you select this option an there are no Scenes in the model. If there are Scenes in the model, then please try to select this option while the Ruby Console window is open. Are there any errors shown?
                                • jiminy-billy-bobJ
                                  jiminy-billy-bob
                                  The only flag causing an issue is "LAYER_HIDDEN_BY_DEFAULT", isn't it?
                                  • JQLJ
                                    JQL
                                    Ahhh! So that's why my models needed fixing everytime!...
                                    www.casca.pt
                                    • J
                                      Jim
                                      thanks!
                                      I could implement editing by using a Listbox instead of a Textbox...
                                      But then I'd need a dialog for the new layer name...
                                      Or perhaps not even have the add new layer option - just have the plugin be a layer behavior editor.
                                      • J
                                        Jim
                                        The option to make the layer "visible on the selected scene only" should work, no?
                                        That's my blog you linked to - and this plugin is an update to the one you linked to.
                                        • K
                                          ktkoh
                                          I downloaded this plugin from the SU Store for the purpose of learning the SKUI interface.
                                          However while testing I was not able to get the check box "Layer visible on selected Scene only" to create a new layer.
                                          Error; #<NameError; undefined local variable or method `txt_LayerName' for JF;;AddLayer;Module>
                                          C;/Users/Keith/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/jf_add_layer/main.rb;155;in `add_layer'
                                          C;/Users/Keith/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/jf_add_layer/main.rb;110;in `block in main'
                                          C;/Users/Keith/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/jf_add_layer/SKUI/events.rb;82;in `call'
                                          C;/Users/Keith/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/jf_add_layer/SKUI/events.rb;82;in `block in trigger_event'
                                          C;/Users/Keith/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/jf_add_layer/SKUI/events.rb;78;in `each'
                                          C;/Users/Keith/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/jf_add_layer/SKUI/events.rb;78;in `trigger_event'
                                          C;/Users/Keith/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/jf_add_layer/SKUI/window.rb;357;in `event_control_callback'
                                          C;/Users/Keith/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/jf_add_layer/SKUI/window.rb;311;in `callback_handler'
                                          C;/Users/Keith/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/jf_add_layer/SKUI/window.rb;269;in `block in add_callback'
                                          C;/Users/Keith/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/jf_add_layer/SKUI/window.rb;203;in `call'
                                          C;/Users/Keith/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/jf_add_layer/SKUI/window.rb;203;in `show_modal'
                                          C;/Users/Keith/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/jf_add_layer/SKUI/window.rb;203;in `show'
                                          C;/Users/Keith/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/jf_add_layer/main.rb;145;in `main'
                                          C;/Users/Keith/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/jf_add_layer/main.rb;185;in `block in <module;AddLayer>'
                                          -e;1;in `call'
                                          The other options worked as expected. Note: this also failed in 2013 with a slightly different error message.
                                          Keith
                                          • J
                                            Jim
                                            Keith - I am looking into this, but can not reproduce it in any version from 2008 thru 2014.
                                            • 1 / 3
