    Layer change inside DC while, using copy
    4 Posts 3 Posters 1.8k Views 3 Watching
    • D
      Dulo
      Hello
      I've created a DC in which I use the copy function.
      It's a sort of a frame, with the partitions made in the copy function.
      So if the frame is 1000mm long there are 4 (3 copies) partitions, if you scale it to 2000mm there are 8 partitions (7 copies)
      However when I load the DC in my new drawing, everyting keeps the layer in which it was created. The DC is in the current layer from the moment I have loaded the DC.
      But when I scale from 1000 to 2000mm, the first 4 partitions keep their original layer, but the new copies are in the current layer. Is there a way to keep the original layer while copying?
      And is it possible to place the layer info in a attribute, to give it trough an attribute to a component? Or to get it from a component and place it in a attribute?
      Thanks a lot in advance, I've should have paid more attention during the English lessons though.
      Regards
      Ludo
      • D
        Dulo
        verry vivid reactions.
        explained my question to difficult?
        • yorik1984Y
          yorik1984
          in this case i apply needed layer to geometry(not components or groups). Is not good, but it working.
          • J
            Jim
            The behavior of the COPIES attribute failing to also copy the Layer would be considered a bug in Dynamic Components.
