    REQ: Tool switching plugin
    4 Posts 3 Posters 378 Views 3 Watching
    • silvershadowS Offline
      silvershadow
      Hi guys
      I have a request, maybe someone has made this or will be willing to help me out here.
      I am looking for a plugin that picks up your last 2 used drawing tools. For example, if I use a lot the line tool and then constantly switching between line and arc, to have a tool i can shortcut, so by pressing it, it chooses line, pressing it again, it switches to arc, instead of going and pick it again. (ignoring pan / orbit / and zooming commands )
      --silvershadow--
      http://i185.photobucket.com/albums/x165/hondsekont/signature_zps98e9736e.jpg
      • cottyC Offline
        cotty
        For this you can use the shortcuts "l" (=line) and "a" (=arc) without the need for a plugin.
        edit:
        you can find an overview of the standard shortcuts here:
        http://dl.trimble.com/sketchup/2013/en/sketchup2013refcardwin.pdf
        my SketchUp gallery
        • BoxB Offline
          You could use Recall Last Tool.
          http://sketchucation.com/forums/viewtopic.php?p=132509#p132509
            silvershadow
            edit:
            I already have both on a shortcut. What i basically wanted was something i can program 2 commands into one shortcut. It sounds stupid i know, but it would be really useful for me.
            For Example: You have the letter X as a shortcut. With that you can put in circle and rectangle in it, so by pressing it once.. it will be circle, pressing it again its rectangle, pressing it again.. its back to circle. Call me lazy, but i don't work with toolbars, everything has a shortcut, and 99% of my work is speed-modeling.
