    How to get info from a face
    5 Posts 4 Posters 461 Views 4 Watching
      d0n
      Hi wanted to learn about making plugins and ran into a problem
      How would i get information from a selected face? I want to use the X,Y,Z of a face inside a component.
      somehow I can't get for the life of me get anything to work 😞
        slbaumgartner
        Please provide more info about what you are trying to do. A Face is a planar surface bounded by a collection of Edges. Each Edge has two end Vertex3d locations, which have x,y,z positions, but there is no single x,y,z associated with a Face.
        • Dan RathbunD Offline
          Dan Rathbun
          @d0n said:
          Hi wanted to learn about making plugins and ran into a problem ...
          ... somehow I can't get for the life of me get anything to work 😞
          You should read my Ruby Newbie's Guide (link in signature.)
          You need to learn standard Ruby. Then you can apply the SketchUp API extensions (which SketchUp loads automatically after loading the Ruby interpreter.)
          I always recommend reading the good old "Pick-Axe" book (posted in the Ruby Resources sticky topic!) from cover to cover.
          You first get a reference to the selected face from the selection collection:
          face = Sketchup::active_model.selection.grep(Sketchup::Face).first
          Assuming you want the first vertex in the face's vertices collection:
          pos = face.vertices.first.position
          pos should be a Geom::Point3d class object.
          I'm not here much anymore.
            d0n
            which function should i look at if i want to get all the vertices of the face?
            • tt_suT Offline
              tt_su
              @d0n said:
              http://www.sketchup.com/intl/en/developer/docs/ourdoc/face.php#vertices
