    Style help
    8 Posts 2 Posters 2.1k Views 2 Watching
    • marked001M
      marked001
      This may exist or it may be impossible, but anyone know if its possible to make a style that fades out the materials, but preserves the linework?? I made this one with just a white watermark but it also fades out the lines. Thanks.
      http://www.revision21vis.com
      instagram: revi21on
        You can't really do that in a single style. Instead export and image with the faded style or whatever you want to do without the lines displayed. Then do a simple Hidden Line export with white background and no shadows. Combine them in an image editor. Put the lines image on a layer above the other and set that layer to Multiply. I do similar things very frequently.
        Here's an example in which I made the faces only export with fog turned on but the Hidden Line export without fog.
        @N08/8388540007/" target="_blank" rel="noopener noreferrer nofollow ugc">
        http://farm9.staticflickr.com/8220/8388540007_69a2c5d6a4.jpg
        • marked001M
          marked001
          Thanks Dave, that's my go to method as well. I'm trying to learn layout and having issues layering viewports. I think I might just update the textures and fade them manually. Thanks for the input!
          instagram: revi21on
            You're welcome. What sort of difficulty are you having with layering viewports?
            • marked001M
              marked001
              Trying to overlay line work over top of a textured viewport, i have to make it a vector, right? When I do this on my elevations there seems to be an issue and 90% of the lines disappear.
              instagram: revi21on
                That's weird. I wonder what's going on with the lines disappearing.
                Yes, in order to see the textures underneath you would need to render the Hidden Line viewport as Vector.
                • marked001M
                  marked001
                  Thanks for confirming that.
                  I've come across a few people with similar problems. There's a lot of lines so I'm guessing its information overload. Thanks for chiming in. I'm going to edit the textures, might end up simpler anyway. Less viewports.
                  instagram: revi21on
                    Good luck with it.
