    🤑 SketchPlus 1.3 | 44 Tools for $15 until June 20th Buy Now
    Maxwell for Sketchup - Sky is black
    extensions
    3 Posts 3 Posters 8.9k Views 3 Watching
      jjent
      Hello - I'm a new Maxwell user, using the Learning Edition system for Sketchup 8 (Free).
      I am trying to see previews of my renders in FIRE and despite having an appropriate-ish EV value and constant dome sun, everything is black. Why???
      Additionally, on the interior, some of my white materials are also very dark, if not also black. What setting am I missing??
      I've attached photos to illustrate.
      • StinkieS Offline
        Stinkie
        It's been some time since I used Maxwell, but could it be you have the alpha channel enabled?
          matt.gordon320
          Judging from the last image you posted and the capture of your settings, I'd recommend changing your "Optics" settings. An fstop of 39.6 is fairly uncommon (most lens that aren't specialty top out around f22), and adjust your shutter speed to something more realistic. Shutter speed in your settings is set to 1/.02, which isn't something you'd ever see in the real world (again, Maxwell relies on realistic settings for its light calcs). Maybe start with 1/30 and go from there?
          It doesn't look like the file is getting errors, and your sky isn't quite "black" as you say. The image is just severely underexposed. Hope that helps! Also as a quick note, for interiors, Maxwell will render significantly cleaner and faster is the interior isn't completely sealed from the outside environment. Transparent materials don't contribute, so try to have one portion of the model open to the outside, perhaps, behind the camera or somewhere out of sight.
