    3D Editable Text
    21 Posts 4 Posters 972 Views 4 Watching
    • ntxdaveN Offline
      ntxdave
      @ntxdave said:
      @box said:
      Not at all, you just need to add thickness or intesect it to remove the ZFighting, it is designed as 3D text.
      You will find Tig's Text Tags more useful for 2D text. They are also editable.
      http://sketchucation.com/forums/viewtopic.php?p=47399#p47399
      I tried the intersect faces and it did not work well and the text was no longer editable.
      Does Tis's 2D text tag allow you to "tie" it to a face so that if I rotate the object (say box) the text rotates with it or does it behave like the standard 2D text which stays in place no matter how I rotate the model or object?
      Thanks - I just downloaded Tig's tool and I can make it work exactly the way I want for the text I am adding to my models much easier that the other tools.
      Now I need to understand how to use the rest of his 2D tool set.
      Press F1...thank me later
      • 2 / 2
