    Import driving me crazy
    3 Posts 2 Posters 349 Views 2 Watching
      Dropout
      Good evening All.
      I am working with a 3D file of a head.
      The file comes from http://www.facegen.com/sampleExports.htm and I'm using the stl solid.
      When I import as inches I get a model that is way too large but is a solid. When I import as mm I get the correct size but not a solid.
      I have tried importing in inches and scaling down but that doesn't seem to be working very well.
      Any ideas anyone?
        driven
        in mm's some faces are probably to small and leaving gaps...
        try meters than scale 1000...
        what importer are you using?
        john
          Dropout
          stl importer by Jim Foltz
          I'll give that a try. Thanks.
