    Issues with cutting abstract shaped surfaces
    4 Posts 2 Posters 326 Views 2 Watching
    • G Offline
      grantboshart
      I need help eliminating part of this object. the end result will be a wheel. the shape i want is enclosed by the red faces. can anyone give me advice on cutting out the rest of this surface? Im not sure what the best method would be.
      Thanks!
      Grant
      wheel face
      wheel image
      • gillesG Offline
        gilles
        First try to select everything, right click, intersect with selection, delete unwanted geometries.
        • G Offline
          grantboshart
          Your a life saver. Thanks! It worked like a charm
          • gillesG Offline
            gilles
            Be my guest.
