    Linear Dimensions On Materials With Angled Ends
    Scheduled Pinned Locked Moved LayOut Feature Requests
    layout
    5 Posts 3 Posters 7.9k Views 3 Watching
    • ashscottA Offline
      ashscott
      Linear dimensions on a piece of material that has angled ends - this works well in Sketchup provided you create the dimension in line with the axes see this example that is not inline with the axes and a similar problem to layout occurs:
      or within the component in line with the component axes (which works in SU):
      but it is not so easy within Layout, perhaps because LO doesn't recognize components and their respective axes?
      See this example of LO's dimension tool showing the overall length of the material incorrectly:
      see this thread for a clear explanation: http://sketchucation.com/forums/viewtopic.php?f=12%26amp;t=56101
      Just some stuff I do with Sketchup.
        • pbacotP Offline
          I agree. Layout needs more powerful dimensioning (and text) to really become a documentation software.
            Peter, are you still using LO3?
            • pbacotP Offline
