    [REQ] Automatic Labels or Dimensions ?
    14 Posts 4 Posters 1.3k Views 4 Watching
      Does this yet existing for a selection of straight lines in one click ?
      http://sketchucation.com/forums/download/file.php?id=115086
      • BoxB Offline
        If you mean like this, then, in a word, Oui.
        Edit, but if you mean multiple in one click, the answer is longer.
          @ Box
          Wanted
          I select some nude straight lines : Then call a plugin (if existing)
          result : all each line selected have now a Dimension or a "lablel of a dimension" !
          (following how the plugin is made)
          • BoxB Offline
            I realised after I posted that you wanted auto on multiple Lines.
            I can't think of anything that will do that just now.
            • sdmitchS Offline
              sdmitch
              True dimensions have a "dynamic" quality that a plugin's add_text can not duplicate. However, if the length label you would get from selecting the midpoint of a line is sufficient, then that can easily be done.
              mod = Sketchup.active_model
              ent = mod.active_entities
              sel = mod.selection
              begin
               edge=sel.first
               spt=edge.start.position
               ept=edge.end.position
               mpt=Geom;;Point3d.linear_combination(0.5,spt,0.5,ept)
               dim=edge.length.to_s
               grp=ent.add_group;ge=grp.entities
               txt=ge.add_text(dim,mpt,[0.5,0.0,0.5])
               txt.leader_type=1
               txt.arrow_type=3
               sel.remove edge
              end until sel.empty?
              http://sdmitch.blogspot.com/
                Cool for the effort... ☀
                But seems there is a glitch
                and very difficult to input on the ruby console without carriage return to line!
                Error; #<SyntaxError; (eval); compile error
                (eval); syntax error, unexpected tIDENTIFIER, expecting $end
                ... ent = mod.active_entities sel = mod.selection begin edge=se...
                (eval)
                Maybe errors come from the difficulties to input inside the ruby console!
                • sdmitchS Offline
                  sdmitch
                  Sorry about that. I always use Ruby Web Console to create and run short plugins such as this one. Here it is as a "one" liner.
                  mod=Sketchup.active_model;ent=mod.active_entities;sel=mod.selection;mod.start_operation "auto label";begin;edge=sel.first;if edge.is_a?(Sketchup;;Edge);spt=edge.start.position;ept=edge.end.position;mpt=Geom;;Point3d.linear_combination(0.5,spt,0.5,ept);dim=edge.length.to_s;grp=ent.add_group;ge=grp.entities; txt=ge.add_text(dim,mpt,[1,0,1]);txt.leader_type=1;txt.arrow_type=3;end;sel.remove edge;end until sel.empty?;mod.commit_operation
                  Just for fun, here is an attempt at creating a "dimension". The problem is that it is so view dependent.
                  mod=Sketchup.active_model;ent=mod.active_entities;sel=mod.selection;mod.start_operation "auto dim";begin;edge=sel.first;spt,vec=edge.line;ept=edge.end.position;dim=edge.length.to_s;vec.length=edge.length/2.0 - dim.length;grp=ent.add_group;ge=grp.entities;ge.add_line spt.offset([0,0,1]),spt.offset([0,0,6]);ge.add_line ept.offset([0,0,1]),ept.offset([0,0,6]);txt=ge.add_text(dim,spt.offset([0,0,5]),vec);txt=ge.add_text("",ept.offset([0,0,5]),vec.reverse);txt.leader_type=1;txt.arrow_type=3;sel.remove edge;end until sel.empty?;mod.commit_operation
                  • G Offline
                    glro
                    That is curious that this follow don't exist in native and difficult to make in Script! 😄
                    [attachment=0:1pedr9ym]<!-- ia0 -->aacurious.jpg<!-- ia0 -->[/attachment:1pedr9ym]
                    Nothing in ruby
                    But TIG gave the basic idea to make it: you store a dimension as a component, then you stretch and move it according to the end position of the edge extremities
                    I used his idea in this plugin
                    http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=55714%26amp;p=506825%26amp;hilit=multiple+dimension+tool#p506825
                    it should be possible to adapt it the way you want it to work, by pre selection
                      @Giro
                      Missed this one! 😳
                      I will exam it! 😄
                      Edit: ok I use it ! It's a cool plug but you must click on each thing! 😄
                      If I have 1000 segments separated i must make 2 * 1000 clicks !
                      Or I miss something as you speek about a "pre selection"
                      Ps And works only on the horizontal plan ! So not so good for my vertical segments! 😉
                        Bravo! ☀
                        Now That is prefect for the first one! 👍
                        Second is more funny 😄
                        Excellent! 👍
                        • G Offline
                          glro
                          i know this plugin doesn't exactly meet the need
                          i just suggested that it would be possible to adapt it, by retrieving the end points of a selection of edges, and adapting a dimension/component to them, in bulk
                          i plan to update the plugin for altitudes, not for vertical edges
                          do you really have 2000 edges to dimension? or is it an hypothesis...
                            it's a little part! 💚
                            So no an hypothesis! 🤓
                            http://sd-2.archive-host.com/membres/up/157426003260176292/11.jpg
                            • G Offline
                              glro
                              here is a plugin that does what you want
                              a video
                              https://dl.dropboxusercontent.com/u/52719814/videos/multiple_edge_dim_tool.webm
                              only vertical edges
                              mult edges dim tool
                                Cool one! ☀
