    [REQ] Automatic Labels or Dimensions ?
    14 Posts 4 Posters 1.4k Views 4 Watching
      @ Box
      Wanted
      I select some nude straight lines : Then call a plugin (if existing)
      result : all each line selected have now a Dimension or a "lablel of a dimension" !
      (following how the plugin is made)
      • BoxB
        I realised after I posted that you wanted auto on multiple Lines.
        I can't think of anything that will do that just now.
        • sdmitchS
          sdmitch
          Does this yet existing for a selection of straight lines in one click ?
          http://sketchucation.com/forums/download/file.php?id=115086
          True dimensions have a "dynamic" quality that a plugin's add_text can not duplicate. However, if the length label you would get from selecting the midpoint of a line is sufficient, then that can easily be done.
          mod = Sketchup.active_model
          ent = mod.active_entities
          sel = mod.selection
          begin
           edge=sel.first
           spt=edge.start.position
           ept=edge.end.position
           mpt=Geom;;Point3d.linear_combination(0.5,spt,0.5,ept)
           dim=edge.length.to_s
           grp=ent.add_group;ge=grp.entities
           txt=ge.add_text(dim,mpt,[0.5,0.0,0.5])
           txt.leader_type=1
           txt.arrow_type=3
           sel.remove edge
          end until sel.empty?
          http://sdmitch.blogspot.com/
            Cool for the effort... โ˜€
            But seems there is a glitch
            and very difficult to input on the ruby console without carriage return to line!
            Error; #<SyntaxError; (eval); compile error
            (eval); syntax error, unexpected tIDENTIFIER, expecting $end
            ... ent = mod.active_entities sel = mod.selection begin edge=se...
            (eval)
            Maybe errors come from the difficulties to input inside the ruby console!
            • sdmitchS
              sdmitch
              Sorry about that. I always use Ruby Web Console to create and run short plugins such as this one. Here it is as a "one" liner.
              mod=Sketchup.active_model;ent=mod.active_entities;sel=mod.selection;mod.start_operation "auto label";begin;edge=sel.first;if edge.is_a?(Sketchup;;Edge);spt=edge.start.position;ept=edge.end.position;mpt=Geom;;Point3d.linear_combination(0.5,spt,0.5,ept);dim=edge.length.to_s;grp=ent.add_group;ge=grp.entities; txt=ge.add_text(dim,mpt,[1,0,1]);txt.leader_type=1;txt.arrow_type=3;end;sel.remove edge;end until sel.empty?;mod.commit_operation
              Just for fun, here is an attempt at creating a "dimension". The problem is that it is so view dependent.
              mod=Sketchup.active_model;ent=mod.active_entities;sel=mod.selection;mod.start_operation "auto dim";begin;edge=sel.first;spt,vec=edge.line;ept=edge.end.position;dim=edge.length.to_s;vec.length=edge.length/2.0 - dim.length;grp=ent.add_group;ge=grp.entities;ge.add_line spt.offset([0,0,1]),spt.offset([0,0,6]);ge.add_line ept.offset([0,0,1]),ept.offset([0,0,6]);txt=ge.add_text(dim,spt.offset([0,0,5]),vec);txt=ge.add_text("",ept.offset([0,0,5]),vec.reverse);txt.leader_type=1;txt.arrow_type=3;sel.remove edge;end until sel.empty?;mod.commit_operation
              • G
                glro
                That is curious that this follow don't exist in native and difficult to make in Script! ๐Ÿ˜„
                [attachment=0:1pedr9ym]<!-- ia0 -->aacurious.jpg<!-- ia0 -->[/attachment:1pedr9ym]
                Nothing in ruby
                But TIG gave the basic idea to make it: you store a dimension as a component, then you stretch and move it according to the end position of the edge extremities
                I used his idea in this plugin
                http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=55714%26amp;p=506825%26amp;hilit=multiple+dimension+tool#p506825
                it should be possible to adapt it the way you want it to work, by pre selection
                  @Giro
                  Missed this one! ๐Ÿ˜ณ
                  I will exam it! ๐Ÿ˜„
                  Edit: ok I use it ! It's a cool plug but you must click on each thing! ๐Ÿ˜„
                  If I have 1000 segments separated i must make 2 * 1000 clicks !
                  Or I miss something as you speek about a "pre selection"
                  Ps And works only on the horizontal plan ! So not so good for my vertical segments! ๐Ÿ˜‰
                    Bravo! โ˜€
                    Now That is prefect for the first one! ๐Ÿ‘
                    Second is more funny ๐Ÿ˜„
                    Excellent! ๐Ÿ‘
                    • G
                      glro
                      i know this plugin doesn't exactly meet the need
                      i just suggested that it would be possible to adapt it, by retrieving the end points of a selection of edges, and adapting a dimension/component to them, in bulk
                      i plan to update the plugin for altitudes, not for vertical edges
                      do you really have 2000 edges to dimension? or is it an hypothesis...
                        it's a little part! ๐Ÿ’š
                        So no an hypothesis! ๐Ÿค“
                        http://sd-2.archive-host.com/membres/up/157426003260176292/11.jpg
                        • G
                          glro
                          here is a plugin that does what you want
                          a video
                          https://dl.dropboxusercontent.com/u/52719814/videos/multiple_edge_dim_tool.webm
                          only vertical edges
                          mult edges dim tool
                            Cool one! โ˜€
