    Dynamic vector Brick pattern
    4 Posts 3 Posters 2.0k Views 3 Watching
    • G
      Gizzieke
      Hi all,
      I’m new here and looking for some help.
      I would like to use Sketchup to make architecture scale models that I can export to DXF and cut on my Laser.
      The problem is the brick pattern …
      I cannot use the fill tool because the pattern is not exported to the DXF files.
      So I need to draw a vector brick pattern on to the wall segments.
      I was wondering if there is any dynamic component that I can use for this, or maybe even make one myself …
      It needs to be able to set a scale and then fill a shape (wall segment) with bricks, avoiding the windows, doors, etc …
      After that I need to be able to make small adjustments to make sure bricks are nicely spaced out at windows, doors and wall endings.
      Any help would be great
      Greetz
      David
      • G
        goga63
        you need it ?
        http://www.youtube.com/watch?v=OmeCQzRtxaU
        http://www.youtube.com/watch?v=ZE-yAwAjRcs
        • G
          Gizzieke
          Hi Goga63,
          That looks like a nice component, but not really what I need...
          In my case I need the componnent to draw the bricks in the 2D view (top view).
          I even don't need to count for the mortar space, sins the laser wil engrave out that space between the bricks.
          Thanks anyway!
          • R
            rodman100
            I'm not sure if this will do what you need but there's a 15 day free trial...http://extensions.sketchup.com/en/content/oob-layouts
            Otherwise why not make the pattern from within a CAD program. I'd imagine most packages have a pattern function.
