    Just started with Layout
    layout
    4 Posts 2 Posters 734 Views 2 Watching
    • S
      sundad
      Title_Block_w_Hydronic_Diagram.pdfTitle_Block_w_Hydronic_Diagram.pdfPlease excuse my simple questions, but I just started with Layout this morning,and I've reached a brick wall.
      I'm trying to import a sketchup drawing into Layout. Attached are the sketchup drawing, and the title block with the same drawing inserted into it. Here are my Q:
      1. Why is the top portion of the dwg cutoff?
      2. How can I redefine the viewport size so as to exclude the "dead air" on the left hand side?
      3. Why does the text get "scrunched up" as I resize the image (both in Sketchup, and in Layout)?
      4. Can I call up Layout from within Sketchup, or do they have to run separately?
      I will try and search out video tutorials, but in the meantime, thought someone could help out with at least one or two of the above questions.
      Thanks!
      • S
        sundad
        I think I just figured out the answers to questions 1 and 2, but still can't answer questions 3 and 4...
        • JQLJ
          JQL
          3 - Text "scrunches up" because it's properties are set up in pt inside sketchup. In model info/entity info you have an option to set a text/leader/dimensio to be, for instance, Arial 12, but you can also set it as Arial 10cm. Try the second and the text will be frozen in place.
          ADVICE: Model all you want in sketchup but label, dimension and write text in layout... You'll have more control like that!
          4 - They run separately but you can refresh a sketchup model from within layout.
          ADVICE: You should set scenes in sketchup that are exactly what you want to print and then use those scenes in Layout, because they get listed there, in the Model Tray. Never mess with scene properties in Layout besides, background, line width, scale, and vector/raster/hybrid modes, and your scenes should stay linked between SU model and Layout.
          www.casca.pt
          Visit us on facebook!
          • S
            sundad
            Much food for thought in your reply. I will keep those points in mind as I practice with the file in the next few days.
            Thanks for responding!
