    3D Triangulation script/method needed
    4 Posts 3 Posters 1.3k Views 3 Watching
    • M
      mustafashredder
      Hello Everyone,
      I need to find a method to triangulate faces to 3d in sketchup. I have seen triangulation scripts but they dont change the surface. I'm sharing the kind of sculpture I want to create.
      https://m1.behance.net/rendition/modules/91263003/disp/6937956395813a709d03b7d2ef327914.jpg
      I already have a decent model of a horse that I would like to triangulate in the manner done above. Kindly suggest a method to do so.
        PolyReducer by Whaat ?
        http://sketchucation.com/forums/download/file.php?id=9249&t=1
        • M
          mustafashredder
          For some reason, the .rb file cant be read by the sketchup (2013) I'm using. I tried the install extension method but it reads only the .rbz file and the copy-paste method doesnt work either.
          This plugin is the solution to my problem but is there a .rbz file available for the same?
          • cottyC
            cotty
            You only have to copy it in the plugin folder (and you need full permission for that folder)...
            (some more infos)
            my SketchUp gallery
