    Plugin idea - component axes - button for show on/off
    18 Posts 7 Posters 858 Views 7 Watching
    • Didier BurD Offline
      Didier Bur
      def dis() opt=Sketchup.active_model.rendering_options["DisplayInstanceAxes"] if opt=false Sketchup.active_model.rendering_options["DisplayInstanceAxes"]=true end if opt=true Sketchup.active_model.rendering_options["DisplayInstanceAxes"]=false end end
      Copy-paste the above code in a rb file and assign it a shortcut. This could do the trick.
      DB
      • robertWanR Offline
        robertWan
        Hi.
        But how?
        Shortcuts .dat
        Extensions .rbz
        plugin .rb, but how initiate from SU? Ruby console?
        I type:
        C:\Program Files (x86)\Google\Google SketchUp 8\Plugins\cos.rb ^ (eval):60: syntax error, unexpected $undefined, expecting $end C:\Program Files (x86)\Google\Google SketchUp 8\Plugins\cos.rb ^> (eval):60
        Robert
        • mitcorbM Offline
          mitcorb
          I am looking at this and trying to discern what you are asking in your last comment. Do you want to know how to assign the shortcut? If you have loaded that ruby script, and it is called DisplayInstanceAxes it should have become a member of the list of Functions. Scroll down the list, and if it is there, select it. You should be able to give it a key sequence in the Add Shortcut box. After that, click the + button.
          If it is not in the list, but it is loaded properly in the Plugins folder, then perhaps close Sketchup and restart it then check if it is present in the Functions list.
            Axes tools by Thomthom is a cool one for place them! 😉
              robertWan
              I don't see DisplayInstanceAxes.
              Robert
              • mitcorbM Offline
                mitcorb
                @RobertWan:
                I don't either. I tried to implement this in Sketchup8.
                However, this was my attempt:
                I copypasted the text into Windows Notepad.(formatting looked same) Saved as filename: DisplayInstanceAxes-dbur.rb file to an intermediate folder and then copied that .rb file into Sketchup8 Plugins folder.
                Opened Sketchup8 to look first in the Shortcut Functions list.
                Did not see anything resembling, except View Axes, which I think is the function for Menu>View>Axes--the Global Axes, not the one you want in this case.
                Looked in the Plugins drop down menu and did not see anything. Also, looked in all of the other Menu drop downs for any clue--not found.
                So... there may be something else missing.
                • sdmitchS Offline
                  sdmitch
                  The if opt=false and if opt=true should have been if opt==false and if opt==true.
                  In order to assign a shortcut to it, you need to assign it to a menu ie. Plugins. In the Preferences>Shortcuts, it will be listed as Plugins/DisplayAxes.
                  module Toggle
                  	def self.dis()
                  		if opt==false
                  		if opt==true
                  	unless file_loaded?(__FILE__)
                  		UI.menu("Plugins").add_item("DisplayAxes") {Toggle.dis}
                  		file_loaded(__FILE__)
                  http://sdmitch.blogspot.com/
                    robertWan
                    Now is ok, thank you.
                    Robert
                    • mitcorbM Offline
                      mitcorb
                      @Robert:
                      Glad you got it working.
                      @sdmitch:
                      Thank you for your time to solve Robert's issue.
                      @Pilou:
                      That is a good alternative.
                      @tetrochuan:
                      Did you decide on something else?
                        laudhi
                        module Toggle
                        > 	def self.dis()
                        > 		if opt==false
                        > 		end
                        > 		if opt==true
                        > 		end
                        > 	end
                        > 	end
                        > end
                        Hi Sdmitch,can you teach me how to add "DisplayInstanceAxes" plugin in "SDM tools" sub menu?
                        • sdmitchS Offline
                          sdmitch
                          replace
                          with this
                          	unless $sdm_tools_menu
                          		$sdm_tools_menu = UI.menu("Plugins").add_submenu("SDM Tools")
                          		$sdm_CorG_tools = $sdm_tools_menu.add_submenu("CorG Tool")
                          		$sdm_CorG_tools.add_item("DisplayAxes") { Toggle.dis }
                            laudhi
                            module Toggle
                            def self.dis()
                            if opt==false
                            if opt==true
                            unless file_loaded?(FILE)
                            file_loaded(FILE)
                            and i found this:
                            Error Loading File DisplayInstanceAxes.rb
                            Error: #<SyntaxError: C:/Users/Laudhi/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/DisplayInstanceAxes.rb:18: syntax error, unexpected end-of-input, expecting keyword_end>
                              laudhi
                              and i found this to :
                              Error Loading File Multiple Offsets.rb
                              Error: #<NoMethodError: undefined method add_item' for nil:NilClass> C:/Users/Laudhi/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Multiple Offsets.rb:185:in <top (required)>'
                              Error Loading File Multi_Offset_Tool.rb
                              Error: #<NoMethodError: undefined method add_item' for nil:NilClass> C:/Users/Laudhi/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Multi_Offset_Tool.rb:30:in <top (required)>'
                              Error Loading File Rotated Box.rb
                              Error: #<NoMethodError: undefined method add_item' for nil:NilClass> C:/Users/Laudhi/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Rotated Box.rb:33:in <top (required)>'
                              Error Loading File Rotated Circle_Cylinder.rb
                              Error: #<NoMethodError: undefined method add_item' for nil:NilClass> C:/Users/Laudhi/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Rotated Circle_Cylinder.rb:30:in <top (required)>'
                              Error Loading File Stair Maker.rb
                              Error: #<NoMethodError: undefined method add_item' for nil:NilClass> C:/Users/Laudhi/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Stair Maker.rb:33:in <top (required)>'
                                Jim
                                This kind of utility is perfect for Custom Toolbars. I have added a toggle_instance_axes command which will be included in the next release. Let me know if you have any more suggestions.
                                • sdmitchS Offline
                                  sdmitch
                                  @laudhi said:
                                  module Toggle
                                  def self.dis()
                                  if opt==false
                                  if opt==true
                                  file_loaded(FILE)
                                  end#<---add this
                                  and i found this:
                                  The end statement for the module is missing.
                                  • sdmitchS Offline
                                    sdmitch
                                    Most if not all of these plugins had to be updated for SU2014 so start by downloading a new copy.
                                      laudhi
                                      ok,thanks for your help Sdmitch....i will update with a new version... 😉
                                        laudhi
                                        i change the name DisplayInstanceAxes.rb to ToggleComAxes.rb and everything works fine now....
