    Plugin idea - component axes - button for show on/off
    18 Posts 7 Posters 1.4k Views 7 Watching
    • mitcorbM
      mitcorb
      @RobertWan:
      I don't either. I tried to implement this in Sketchup8.
      However, this was my attempt:
      I copypasted the text into Windows Notepad.(formatting looked same) Saved as filename: DisplayInstanceAxes-dbur.rb file to an intermediate folder and then copied that .rb file into Sketchup8 Plugins folder.
      Opened Sketchup8 to look first in the Shortcut Functions list.
      Did not see anything resembling, except View Axes, which I think is the function for Menu>View>Axes--the Global Axes, not the one you want in this case.
      Looked in the Plugins drop down menu and did not see anything. Also, looked in all of the other Menu drop downs for any clue--not found.
      So... there may be something else missing.
      • sdmitchS
        sdmitch
        The if opt=false and if opt=true should have been if opt==false and if opt==true.
        In order to assign a shortcut to it, you need to assign it to a menu ie. Plugins. In the Preferences>Shortcuts, it will be listed as Plugins/DisplayAxes.
        module Toggle
        	def self.dis()
        		opt=Sketchup.active_model.rendering_options["DisplayInstanceAxes"]
        		if opt==false
        			Sketchup.active_model.rendering_options["DisplayInstanceAxes"]=true
        		if opt==true
        			Sketchup.active_model.rendering_options["DisplayInstanceAxes"]=false
        	unless file_loaded?(__FILE__)
        		UI.menu("Plugins").add_item("DisplayAxes") {Toggle.dis}
        		file_loaded(__FILE__)
        http://sdmitch.blogspot.com/
        • robertWanR
          robertWan
          Now is ok, thank you.
          Robert
          • mitcorbM
            mitcorb
            @Robert:
            Glad you got it working.
            @sdmitch:
            Thank you for your time to solve Robert's issue.
            @Pilou:
            That is a good alternative.
            @tetrochuan:
            Did you decide on something else?
            • L
              laudhi
              module Toggle
              > 	def self.dis()
              > 		if opt==false
              > 		end
              > 		if opt==true
              > 		end
              > 	end
              > 	end
              > end
              Hi Sdmitch,can you teach me how to add "DisplayInstanceAxes" plugin in "SDM tools" sub menu?
              • sdmitchS
                sdmitch
                replace
                with this
                	unless $sdm_tools_menu
                		$sdm_tools_menu = UI.menu("Plugins").add_submenu("SDM Tools")
                		$sdm_CorG_tools = $sdm_tools_menu.add_submenu("CorG Tool")
                		$sdm_CorG_tools.add_item("DisplayAxes") { Toggle.dis }
                • L
                  laudhi
                  module Toggle
                  def self.dis()
                  if opt==false
                  if opt==true
                  unless file_loaded?(FILE)
                  file_loaded(FILE)
                  and i found this:
                  Error Loading File DisplayInstanceAxes.rb
                  Error: #<SyntaxError: C:/Users/Laudhi/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/DisplayInstanceAxes.rb:18: syntax error, unexpected end-of-input, expecting keyword_end>
                  • L
                    laudhi
                    and i found this to :
                    Error Loading File Multiple Offsets.rb
                    Error: #<NoMethodError: undefined method add_item' for nil:NilClass> C:/Users/Laudhi/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Multiple Offsets.rb:185:in <top (required)>'
                    Error Loading File Multi_Offset_Tool.rb
                    Error: #<NoMethodError: undefined method add_item' for nil:NilClass> C:/Users/Laudhi/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Multi_Offset_Tool.rb:30:in <top (required)>'
                    Error Loading File Rotated Box.rb
                    Error: #<NoMethodError: undefined method add_item' for nil:NilClass> C:/Users/Laudhi/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Rotated Box.rb:33:in <top (required)>'
                    Error Loading File Rotated Circle_Cylinder.rb
                    Error: #<NoMethodError: undefined method add_item' for nil:NilClass> C:/Users/Laudhi/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Rotated Circle_Cylinder.rb:30:in <top (required)>'
                    Error Loading File Stair Maker.rb
                    Error: #<NoMethodError: undefined method add_item' for nil:NilClass> C:/Users/Laudhi/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Stair Maker.rb:33:in <top (required)>'
                      Jim
                      This kind of utility is perfect for Custom Toolbars. I have added a toggle_instance_axes command which will be included in the next release. Let me know if you have any more suggestions.
                      • sdmitchS
                        sdmitch
                        @laudhi said:
                        module Toggle
                        def self.dis()
                        if opt==false
                        if opt==true
                        file_loaded(FILE)
                        end#<---add this
                        and i found this:
                        The end statement for the module is missing.
                        • sdmitchS
                          sdmitch
                          Most if not all of these plugins had to be updated for SU2014 so start by downloading a new copy.
                          • L
                            laudhi
                            ok,thanks for your help Sdmitch....i will update with a new version... 😉
                            • L
                              laudhi
                              i change the name DisplayInstanceAxes.rb to ToggleComAxes.rb and everything works fine now....
