    Pushpull makes google 8 to crash
    4 Posts 2 Posters 382 Views 2 Watching
    • N
      nics
      hi guys, when I do a pushpull in my ruby script that the result ends on another surface, google 8 crashes. I dont't remember with which version I made this script (long time ago) but this was working. If I pushpull with a smaller value to avoid ending to the another surface, it works and then I'm ble to manually pushpull the remaining gap.
      what's wrong ? thanks
      • TIGT
        Without seeing the code who knows ?
        We are now in 2014 so v8 itself is looking old... 😒
        Perhaps you could try doing the changes in a group then explode it ?
        • N
          nics
          here's the code to build a door with its frame around, sorry its in french .. as you can see, there's a base.pushpull(-hauteur+"1/32".to_l) .. the 1/32 is to avoid the crash ...
          require 'sketchup.rb'
          module PorteBuilder
          class Porte
              attr_accessor ;espaceBas, ;espaceHaut, ;espaceCote, ;charniereEspaceBas, ;charniereEspaceHaut, ;poigneeEspaceBas, ;hauteur, ;largeur, ;epaisseur, ;frontFace
              def initialize(espaceBas, espaceHaut, espaceCote, charniereEspaceHaut, charniereEspaceBas, poigneeEspaceBas,
          	               hauteur, largeur, epaisseur)
                @espaceBas = espaceBas
          	  @espaceHaut = espaceHaut
          	  @espaceCote = espaceCote
          	  @charniereEspaceHaut = charniereEspaceHaut
          	  @charniereEspaceBas = charniereEspaceBas
          	  @poigneeEspaceBas = poigneeEspaceBas
          	  @hauteur = hauteur
          	  @largeur = largeur
          	  @epaisseur  = epaisseur
              end # initialize
              def draw()
               	model = Sketchup.active_model
                  entities = model.entities
                  group = entities.add_group
                  entities = group.entities
          		# dessiner la base de la porte
          		basePts = []
          		basePts[0] = [0, 0, @espaceBas]
          		basePts[1] = [@largeur, 0, @espaceBas]
          		basePts[2] = [@largeur, @epaisseur, @espaceBas]
          		basePts[3] = [0, @epaisseur, @espaceBas]
          		base = entities.add_face basePts
          		@hauteur = -@hauteur if( base.normal.dot(Z_AXIS) < 0 )
          		# faire une porte avec la base
          		array_before = entities.to_a
          		base.pushpull(@hauteur)
          		array_after = entities.to_a
          		new_entities = array_after - array_before
          		# aller chercher la face qui aura la poignée
          		faces=[]
          		new_entities.each{|e|faces<<e if e.class==Sketchup;;Face}
          		normalizeVector = (Geom;;Vector3d.new 0,1,0).normalize!
          		faces.each{|face|
          		  resultClassify = face.classify_point(basePts[0])
          		  if (face.normal.parallel? normalizeVector and resultClassify == Sketchup;;Face;;PointOnVertex)
          			@frontFace = face
          			break
          		# bâtir le trou de la poignee
          		rayonPoignee = '1 1/4"'.to_l
          		posXPoignee = @largeur - '2 3/8"'.to_l - rayonPoignee
          		posYPoignee = 0
          		posZPoignee = @poigneeEspaceBas + @espaceBas
          		centrePoignee = Geom;;Point3d.new posXPoignee, posYPoignee, posZPoignee
          		# décider de la normal de la poignee
          		normalPoignee = (Geom;;Vector3d.new 0,1,0).normalize!
          		edgesPoignee = entities.add_circle centrePoignee, normalPoignee, rayonPoignee
          		facePognee = ( edgesPoignee.first.faces.to_a - [@frontFace] ).first
          		facePognee.pushpull -@epaisseur
          	end # draw
          end # class Porte
          class Moulure
          	largeur='3 1/2"'.to_l
          	epaisseur='3/4"'.to_l
          end # class Moulure
          class Montant
              attr_accessor ;largeur, ;epaisseur
              def initialize(largeur, epaisseur)
          	   @largeur = largeur
          	end # initialize
              def draw(porte)
          	   normalFrontFace = porte.frontFace.normal
          	   nearestPoint=nil
          	   porte.frontFace.edges.each{|edgeFrontFace|
                    linesPoint3d=[]
          		  edgeFrontFace.line.each{|e|linesPoint3d<<e if e.class==Geom;;Point3d}
          		  linesPoint3d.each{|linePoint3d|
          		     point = [0,0,0]
          		     if (nearestPoint == nil or ((linePoint3d.distance point) < (nearestPoint.distance point)))
          			    nearestPoint = linePoint3d
           	   startingPoint = nearestPoint.offset [-porte.espaceCote-@epaisseur, 0, +porte.hauteur+porte.espaceHaut]
          	   drawPart(startingPoint, @epaisseur*2 + porte.largeur + porte.espaceCote*2, @largeur, @epaisseur)
          	   startingPoint = nearestPoint.offset [-porte.espaceCote-@epaisseur, 0, -porte.espaceBas]
          	   drawPart(startingPoint, @epaisseur, @largeur, porte.espaceBas + porte.hauteur + porte.espaceHaut)
          	   startingPoint = nearestPoint.offset [porte.largeur+porte.espaceCote, 0, -porte.espaceBas]
             end # draw
             def drawPart(startingPoint, offsetX, offsetY, hauteur)
                 begin
          		   basePts=[]
          		   basePts[0] = startingPoint
          		   basePts[1] = basePts[0].offset [+offsetX, 0, 0]
          		   basePts[2] = basePts[1].offset [0, offsetY, 0]
          		   basePts[3] = basePts[2].offset [-offsetX, 0, 0]
          		   else
               		   base.pushpull(hauteur)
                 rescue
                    puts $!, $@
             end # drawPart
          end # class Montant
          end # module PorteBuilder
          prombasePts = ["Hauteur?", "Largeur?", "Profondeur"]
          values = ['80"'.to_l, '30"'.to_l, '1 7/8"'.to_l]
          results = UI.inputbox prombasePts, values, "Dimension de votre porte ?"
          return if not results # This means that the user canceld the operation
          height, width, depth = results
          #espaceBas, espaceHaut, espaceCote, charniereEspaceHaut, charniereEspaceBas, poigneeEspaceBas, hauteur, largeur, epaisseur)
          unePorte = PorteBuilder;;Porte.new('3/4"'.to_l, '1/16"'.to_l, '1/16"'.to_l, '7"'.to_l, '11"'.to_l, '36"'.to_l, '80"'.to_l, '30"'.to_l, '1 7/8"'.to_l)
          unePorte.draw()
          lesMontant = PorteBuilder;;Montant.new('3 1/2"'.to_l, '3/4"'.to_l)
          lesMontant.draw(unePorte)
          • TIGT
            Here's a version that works, with undo, and a menu etc...
            module PorteBuilder
                class Porte
            			@hauteur = hauteur
            			@largeur = largeur
                    end # initialize
                    def draw()
                        group = entities.add_group()
                      basePts = []
                      base = entities.add_face(basePts)
                      new_entities.grep(Sketchup;;Face).each{|face|
                        if (face.normal.parallel?(Y_AXIS) && resultClassify == Sketchup;;Face;;PointOnVertex)
            				@frontFace = face
            				break
                      rayonPoignee = 1.25.inch
                      posXPoignee = @largeur - 2.0375.inch - rayonPoignee
                      posYPoignee = 0
                      centrePoignee = Geom;;Point3d.new(posXPoignee, posYPoignee, posZPoignee)
                      edgesPoignee = entities.add_circle(centrePoignee, Y_AXIS, rayonPoignee)
                      facePognee = ( edgesPoignee[0].faces - [@frontFace] )[0]
                      facePognee.pushpull(-@epaisseur)
                   end # draw
                end # class Porte
                class Moulure
                   largeur = 3.75.inch
                   epaisseur = 0.75.inch
                end # class Moulure
                class Montant
            		  group=entities.add_group()
            		  @entities=group.entities
                      @largeur = largeur
                    end # initialize
                    def draw(porte)
                      nearestPoint=nil
                        linesPoint3d=[]
                           point = ORIGIN.clone
                           if nearestPoint == nil || linePoint3d.distance(point) < nearestPoint.distance(point)
                      startingPoint = nearestPoint.offset [-porte.espaceCote-@epaisseur, 0, porte.hauteur+porte.espaceHaut]
                      drawPart(startingPoint, @epaisseur*2+porte.largeur+porte.espaceCote*2, @largeur, @epaisseur)
                      drawPart(startingPoint, @epaisseur, @largeur, porte.espaceBas+porte.hauteur+porte.espaceHaut)
                   end # draw
                       begin
                         basePts=[]
                         basePts[1] = basePts[0].offset [offsetX, 0, 0]
                         base = @entities.add_face(basePts)
                         if base.normal.dot(Z_AXIS) < 0
                            base.pushpull(-hauteur + 0.03125.inch)
                         else
                       rescue
                          puts $!, $@
                   end # drawPart
                end # class Montant
            	def self.dialog()
            		values = [80.0.inch, 30.0.inch, 1.875.inch]
            		results = inputbox(prombasePts, values, "Dimension de votre porte ?")
            		return unless results # This means that the user canceld the operation
            		Sketchup.active_model.start_operation('PorteBuilder')
            			unePorte = PorteBuilder;;Porte.new(0.75.inch, 0.0625.inch, 0.0625.inch, 7.0.inch, 11.0.inch, 36.0.inch, height, width, depth)
            			unePorte.draw()
            			lesMontant = PorteBuilder;;Montant.new(3.5.inch, 0.75.inch)
            		Sketchup.active_model.commit_operation
            	UI.menu("Plugins").add_item('PorteBuilder'){self.dialog()} unless file_loaded?('PorteBuilder')
            	file_loaded('PorteBuilder')
            I'm unsure of the exact issue.
            Your code seems more complex than it needs to be 😕
            Why not draw the vertical face for the inverted U of the door-frame and pushpull that inside a door-frame-group, then draw the vertical face of the door-leaf and pushpull that inside a door-leaf-group, with the hole punched out for the ironmongery ?
            That way you control the face orientation - the counter-clockwise points around a face loop determine its normal vector.
            If you want door-stops add those inside a door-stop-group, in a manner similar to the frame itself: it can be inside the frame group too.
            You really don't need so many classes as a range of methods self.xxx() would do whatever you want with in the module, and using @xxx variables would make them available across the module too... 😕
