    X-ray transparency settings?
    5 Posts 4 Posters 1.6k Views 4 Watching
    • onidarbeO Offline
      onidarbe
      Does anyone know if I can change the X-ray transparency amount?
      thanks
      • Dan RathbunD Offline
        Dan Rathbun
        Check the rendering options hash of the model object.
        model.rendering_options
        http://www.sketchup.com/intl/en/developer/docs/ourdoc/renderingoptions
        πŸ’­
        I'm not here much anymore.
        • onidarbeO Offline
          onidarbe
          I guess not 😞
          Didn't find anything useful here:
          http://www.sketchup.com/intl/en/developer/su-api/rendering__options_8h.html
          • pbacotP Offline
            This would be fixed if LO had simple opacity controls in layers.
              You can only get/set and toggle Xray-mode on/off using:
              Sketchup.active_model.rendering_options["ModelTransparency"] Sketchup.active_model.rendering_options["ModelTransparency"]=true Sketchup.active_model.rendering_options["ModelTransparency"]=false
              The amount of Xray-mode's 'opacity' is 'hard-coded' 😞
              Fredo has made a pseudo Xray-mode tool [can't recall it's name off-hand πŸ˜• ], which works on selected objects, but that just swaps to similar but translucent materials [you could customize the amount of transparency in it] - so although it mimics Xray for parts of the model, it is only useful 'graphically' in images - there are none of the Xray-mode's advantages - like being able to pick 'through' intervening faces etc...
