    Special Characters in ENV[APPDATA] not recognized
    6 Posts 5 Posters 536 Views 5 Watching
    • R
      Rubycation
      I am trying to write some config files for an extension to an users roaming appdata folder but it doesn't work when special characters are used in the user name.
      How would you deal with an username containing an ë or é? When for example the Windows Username is 'Tëst' the ENV[APPDATA] will come back with 'Tst'. This results in the inability to write the configuration file.
      Thank you for your reply!
      Alex
      • Dan RathbunD
        Dan Rathbun
        On Windows Ruby in the 1.8 trunk cannot handle paths with Unicode characters. This causes many methods in the Ruby Dir, File and IO classes to fail.
        You will have to use Tig's PCFileTools library along with WIN32OLE class.
        I'm not here much anymore.
        • Dan RathbunD
          Dan Rathbun
          Note that ENV interface may still return unicode characters as escaped numerics:
          %(#804000)['C:\Users\Półka\AppData\Roaming']
          may be returned as:
          "C:\\Users\\P\242lka\\AppData\\Roaming"
          • TIGT
            Hopefully when [if] SketchUp gets a 'good' newer version of Ruby this PC limitation will disappear.
            If you want to allow for the less esoteric characters like é this way returns true properly - no incorrect false...
            s="C:/Users/P**ó**lka/xxx.txt" File.exist? s.unpack("U*").map{|c|begin;c.chr;rescue;c;end}.join
            BUT then
            C:/Users/Pó**ł**ka/xxxx.txt
            still returns false wrongly !
            • tt_suT
              tt_su
              You might be able to extract the DOS 8.3 path from EVV['TEMP']. Ruby 1.8 can use DOS 8.3 paths is you have them.
              • AdamBA
                AdamB
                The only way around this I found was to write all my own Filepath handling in C++ for LightUp so handling Kanji, etc etc all works correctly.
